timing issue
Old Aug 6, 2008 | 05:21 PM
Bluto's Avatar
Bluto
timing issue
75 f-100 390 2bbl from factory got a re-built 400 now. I'm a total rookie mechanic but I want to try to adjust the timing slightly and see if I can get a better idol.
what do you loosen so the distributer can be turned?
Thanks for the help.
B
Old Aug 6, 2008 | 05:27 PM
fmc400's Avatar
fmc400
MSEE
There is a hold-down clamp with a bolt under the distributor. On many 400's, it takes a special distributor wrench, but depending on how cluttered your accessory drive is, you may be able to get away with a crow's foot or just a box-end.
Just as a side note, this really isn't the way to go about your issue. Timing is something you should set to specification. Turning the distributor blindly is going to cause problems for you. A timing light with white paint is the proper way to time an engine. If you have idle problems with the timing set to spec, you have other issues, such as a possible vacuum leak or poorly-tuned carburetor. If you need to check your timing, we can go over the procedure for this, but I don't recommend doing what you're set out to do as it stands. If you're having problems with your idle, describe them and we'd all be happy to lend a hand!
Old Aug 6, 2008 | 05:30 PM
1985 Ford F-150's Avatar
1985 Ford F-150
Welcome to FTE. There is a little bolt at the base of the dist on top of the hold down. Should be a half inch size just lossen it up then turn the dist where you want it. When you get it where you would like it then just tighten it down again.
Old Aug 6, 2008 | 05:50 PM
73f100shortbed's Avatar
73f100shortbed
Like said loosen bolt on hold-down to rotate distributor, but I agree with fmc400 that you might have a different problem.
Old Aug 6, 2008 | 06:08 PM
Thunderjet4x4's Avatar
Thunderjet4x4
+1 on the above info! If you do have to adjust-be warned, the distributor may be seized into the block-it does happen on these old engines.
Old Aug 6, 2008 | 06:47 PM
fozzy's Avatar
fozzy
IIRC counterclockwise will advance it, raising rpms, leaning out the engine, so you will have to lower idle with the screw. It willbe hard to start if it is advanced too much.
clockwise will retard the timing, and will have opposite affects as above.
am i right on the direction to advance/retard anyone?
Old Aug 6, 2008 | 08:35 PM
1985 Ford F-150
Thats what it is on FEs but not sure bout much else.
Old Aug 11, 2008 | 09:33 AM
Bluto's Avatar
Bluto
Thanks for the feedback guys!!! Y'all have convinced me to leave the timing alone. This truck runs GREAT once I get it on the road. The timing must be good..right? I now believe i have a carb issue...fuel/air maybe.???
i had a shop put a re-built carb on it about a year ago. I don't drive this truck much at all. The carb is clean as a whistle. I had a nagging problem of the carb overflowing so I bent the float tang til it quit. Now I have the idle problem. I suppose it is time to go to a carb guy and let a pro do it. Working on these carbs is more like an art than a science. Other than bending the float back a little and risking the overflow problem returning...I'm out of ideas.
Thoughts??
B
Old Aug 11, 2008 | 12:11 PM
fmc400's Avatar
fmc400
MSEE
Setting the float is not a trial-and-error procedure, it must be set exactly to factory specification because even being 1/16" off can make you flood out. Unfortunately there are no sight plugs or similar conveniences on a stock 2-barrel carburetor. There are two ways to do it on a stock carburetor - a wet-check procedure which is tricky especially if you don't have experience working on carbs, and a dry-check which is done with the carburetor off the engine during the carb rebuild.
Old Aug 13, 2008 | 08:18 AM
Bluto's Avatar
Bluto
Great feedback. Since i have decided not to mess with the timing, how about some help with this idle problem.
The truck runs great on the road. She cranks easily...but I have to feather the gas peddle to keep her running. When I put her in drive or reverse I have to give it gas to keep it cranked. I even have to slip into neutral when coming to a stop and work the gas to keep running.
Again...She runs strong on the road...just can't get a decent idle. BTW...had a re-built carb put on @ a year ago and idled fine for awhile. Then I started getting overflow from the carb. I replaced needle and seat...still overflowed. I bent the float just enough to stop the overflow and that's when the idle problem showed up. I do have the wet check gauge and have it as close as I can get it to spec. When I had it dead on spec...the overflow problem comes back. Too bad they didnt have EFI in 1975.
Thanks
B
Old Aug 13, 2008 | 09:06 AM
fmc400's Avatar
fmc400
MSEE
What do you mean by wet check gauge? All you do a wet check with is a small ruler. Is that what you meant?
Can you describe what you did to check the wet float height? If you set it to spec, it should not flood out. If it does flood out, something is installed incorrectly, or you are not measuring the height properly, which is why I have asked you to tell me how you did it. We can troubleshoot from there.
