only getting 10 psi...
Old Aug 6, 2008 | 04:04 PM
secondarychaos's Avatar
secondarychaos
Hey guys.
after my gauge installation, i was seeing 14-15 psi of boost. it slowly worked down to where now i'm only seeing 10 psi. with this came a small reduction in power. I checked all my gauge connections, map line connections, air filter, and cant seem to solve the problem.
any ideas? thanks!
Edit: i did run my tanks really low this last time, so maybe clean FPR screen???
Old Aug 6, 2008 | 04:29 PM
c00nhunterjoe's Avatar
c00nhunterjoe
possible, but look for exhaust leaks behind the motor as well. check for any boost leaks
Old Aug 6, 2008 | 04:41 PM
Cuda_jim's Avatar
Cuda_jim
I doubt the FPR screen has anything to do with boost levels. Maybe the gage is just messed up. Try checking it against a known good gage or just disconnect it and see if it runs better. 14-15 lbs seems a bit low 10 psi is really low....18-20 is normal....no mods.
Old Aug 6, 2008 | 04:45 PM
secondarychaos
I was just thinking maybe it wasnt getting enough fuel to make more boost.
common spots for exhaust leaks? i can check the whole intake path myself, that's not hard.
Old Aug 6, 2008 | 04:48 PM
c00nhunterjoe
th upipes on the exhaust right by the turbo is the most common, however i have seen the manifolds themselves leak on high salt use and bolts rot off.
14-15 isnt bad, i have ridden in plenty of stockish trucks that peak at 15 psi. some just produce more than others.
Old Aug 6, 2008 | 04:49 PM
Cuda_jim's Avatar
Cuda_jim
Exh leaks are easy to spot, look for black soot
Intake for leaks can be hard to find. A pin hole will cause low boost.
Old Aug 6, 2008 | 05:00 PM
secondarychaos
Ok, so is it safe to assume that if i dont have an exhaust leak, i do have an intake leak?
I kinda planned on replacing those boots anyways. joe, didnt you just do that for yours? where and how much for the boots?
Thanks guys. I tried to rep both of you but need to spread more love lol
Old Aug 6, 2008 | 05:02 PM
c00nhunterjoe
you do have an intake leak???? and what boots are you referring to?
Old Aug 6, 2008 | 05:05 PM
secondarychaos
I dont see any soot, so that's my guess. I'm reffering to the orange boots that connect the y pipe to the intake manifold.
Old Aug 6, 2008 | 05:10 PM
c00nhunterjoe
do you have an intercooler? typicly neither set of boots go bad, check for oily residue if you still have the ccv in stock location.
Old Aug 6, 2008 | 05:13 PM
secondarychaos
No IC, but didnt I just see a post about intake boots going bad? CCV is stock still, but i was thinking it didnt matter without a IC
Old Aug 6, 2008 | 05:17 PM
c00nhunterjoe
hmm, it wasnt my intake boots. i dont recall it. but if yours are leaking you will probably have a black oily residue all over them. and the turbo snout where the hose/worm clamp is would possibly have some as well
Old Aug 6, 2008 | 05:19 PM
secondarychaos
hmm... dont have that either. they're dirty, but not oily. how much oil comes out of the CCV???
Old Aug 6, 2008 | 05:25 PM
c00nhunterjoe
not a whole lot but it accumulates over time
Old Aug 6, 2008 | 05:29 PM
secondarychaos
Ok, well i guess i'm going to have to check my exhaust better then. What would be the procedure to fix an exhaust leak?
