The problem with these numbers is they really don't tell you what motor you have, you need to identify the family by other means. The basic engine block ID is 6015, but this sequence applies to all engine families. If you have a 302 block the E7 casting will be roller ready, but if it's a 351 block it's not, and same goes for the big block. Do you know generally what motor you have?
