96' issues in high R's and low speed
ok heres the deal, my truck breaks up at WOT at like 4-5200 rpms...bucks, sputters, farts, belches, its running lean and backfires through the air intake....timing is on, put it on a modis and my pip lines up with the timing on a graph, good fuel pressure, serviced all the time by me, 150K, i think it might be the coil but seems to ohm out fine, new tune up with msd stuff... shorty's to high flow Y and 3inch fake duals.....it also bucks in like 3rd at 25mph, and in 2nd on light throttle... along with the r's hanging(i think tps).... can u help me??? it got this issue after mudding and i submerged it like 5times...lol but it didn't die just ran horrible for a while...i think its the coil i accidently hit the coil with the power washer and same prob occured like i was wheeling, its a quick truck seems fine until i cruise or WOT it??someone help plz!!!! thanks any opinions??? BTW 5.0 5speed 2wd
lol..the headlights only went under...i hope its not the pcm...i love the headers if i could only keep the bolts tight...thanks bro nice truck btw
on
Unfortunantely that's right where the air intake is.
Count yourself one lucky somnabiatch you didn't hydrolock the motor and pretzalise a few rods.
Your best bet is to pull the codes to see what comes up, there are lots of things that could cause your problem.. from plugs to a bad sensor, the codes will help eliminate a lot of possibilities.
