Master cylinder or booster?
Old Aug 5, 2008 | 08:43 PM
67lunargreen's Avatar
67lunargreen
Okay got the truck on the road. I have to pump up the brakes, then they work great. If I go a block they are gone. Just finished brakes except master cylinder. I found that the vaccum lines and check valve were bad. I replaced that and now the truck will die if I keep the brake pedal down, still no brakes. Which one do I need to replace or both?
Old Aug 5, 2008 | 09:24 PM
Freightrain's Avatar
Freightrain
You either still have alot of air in the master cylinder or it's bad.
Try this: bleed the master cylinder itself. When you buy a new master, it comes with the parts to do this. 2 plastic fitttings and nylon tubing. Fill the master cylinder, take the line from each fitting and put back into corresponding resevior(submerge in fluid). Pump the master til no air is seen in the lines. Hook back up to truck and then re-bleed the whole system. Don't push on pedal until lines are hooked up, as you'll then suck air into master again.
As for truck stalling with brakes applied? Sounds like possible vacuum leak in power booster? Unhook/plug the line so brake booster is not hooked up. Does it still stall? Then it's not brake booster.
WantFordF250
Oct 6, 2008 08:18 PM
64STYLE
Jul 12, 2007 06:30 PM
Nightrain
Dec 4, 2005 11:01 PM
antitorque
Jan 9, 2004 12:47 AM
Jul 14, 2001 06:50 PM
