Offroad & 4x4
So Can I Do This?
Old Aug 5, 2008 | 05:34 PM
dgsm24's Avatar
dgsm24
So Can I Do This?
i have a 94 150 with the 4.9 4x4 an i usually have 35 mud terrians on there, but for this weekends mudruns i want to put the 38 super swampers i have. last time i did this, both the return line and the vacuumed line blew out, prob from being original ones. All i am going through is sloooshhhy muck, nothing with climbs or rocks, stumps. So do you think this time it will be ok when if i put the 38's back on there? saginaw is my next upgrade fo sho!
Old Aug 5, 2008 | 05:51 PM
ibleedblue1385's Avatar
ibleedblue1385
There is only one way to find out...
That ttb is not going to be happy with you dealing with those 38" meats.
Old Aug 6, 2008 | 07:06 AM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
Yea with the huge amounts of power the 4.9 ISNT putting out then you should be OK with the ttb. Just stay out of the throttle at full crank.
Old Aug 6, 2008 | 04:11 PM
dgsm24's Avatar
dgsm24
what is ttb?....and i got a k&n air filter so this 4.9 has pleanty of power!............ha jk
Old Aug 6, 2008 | 04:28 PM
JBradley500's Avatar
JBradley500
twin traction beam front suspension
Old Aug 6, 2008 | 07:30 PM
Truckin4life
short for twin traction beam, its your front axle. Has IFS, which is notorious for breaking with bigger tires and bigger power. Hence why sas is such a popular thing to do on these trucks, sas being Solid Axle Swap. I just put 37" tires on my truck and i really try to keep my foot out of it while the hubs are locked, just cause i know that my ttb is gunna go boom soon.
Old Aug 7, 2008 | 05:39 AM
Green Ford's Avatar
Green Ford
TTB + Large Tires = Ticking time bomb
Old Aug 7, 2008 | 05:47 AM
fishmanndotcom's Avatar
fishmanndotcom
just run them. however i will be surprised if you are able to turn those tires once you get in the middle of the pit. if the mud in your area is true mud your setup doesnt stand a chance on 38's b/c i'm sure your gearing is 3.55. also, i would not suggest turning too hard while on the throttle.
-cutts-
Old Aug 7, 2008 | 06:50 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
-cutts-
Dont listen to him. Just lock it in 4 lo and turn the wheels to complete lock and mash the gas. then youl know if you can handle 38s
Airborne-F250
18
Mar 8, 2017 07:45 PM
Jeff heine
Apr 30, 2016 08:31 PM
Boba Fett
Feb 22, 2015 07:57 AM
afinepoint
Garage & Workshop
20
Dec 16, 2012 07:33 AM
78fordman
Dec 4, 2003 10:09 PM
