front third member stuck
Old Aug 5, 2008 | 03:31 PM
shadowf150's Avatar
shadowf150
Cool front third member stuck
88 f150. have differntital out bearing caps off but the third member wont budge. cant get it out for the life of me. anyideas?????
Old Aug 5, 2008 | 03:54 PM
danr1's Avatar
danr1
Ok I'll ask,
You did pull the axles right?
Old Aug 5, 2008 | 03:57 PM
andym's Avatar
andym
That was my first thought, but it's tough to get the bearing caps off with the third member still in the housing.
What he means is that the carrier is stuck in the case. I don't know what else would be keeping it in place, so it will probably pop out with the right force.
Old Aug 5, 2008 | 04:06 PM
danr1's Avatar
danr1
<i>That was my first thought, but it's tough to get the bearing caps off with the third member still in the housing.</i>
Yea, I see what you mean, but what axle does he have, and what exactly does he consider a "third member"? lol!
Old Aug 5, 2008 | 04:12 PM
alxsnmr's Avatar
alxsnmr
If he is talking about the Differential stuck in the case, he may have to use a case spreader to make the case open up so that it does not pinch the bearings in place. If it was the rear axle and he was trying to pop it out the back end, I used a come-along attached to the rear bumper of the truck. Getting it back in was a horrible PITA.
Old Aug 5, 2008 | 04:13 PM
andym's Avatar
andym
Well, he says it's an 88 F-150, and the front "third member" is stuck, so I'm assuming he's talking about the Dana 44. It wouldn't be the first time I misunderstood someone.
It's sure a challenge figuring out what folks are trying to say, especially when they use some terms interchangeably with others.
Old Aug 5, 2008 | 04:17 PM
qman's Avatar
qman
I cracked up when I read the title of this thread. I had a different suggestion.
Old Aug 5, 2008 | 04:24 PM
danr1's Avatar
danr1
Oh yup missed the part about it being the "front" so yea he'd have to have the axles out.
Yea get a big pry bar and work it out, make sure you allow the pinion to rotate as it comes out. If it is kept from spinning it would hold it in place and fight to work against you.
Old Aug 5, 2008 | 04:29 PM
danr1's Avatar
danr1
Yea, he might want to seek help elsewhere for that........issue! lol
Old Aug 5, 2008 | 04:31 PM
alxsnmr's Avatar
alxsnmr
I have heard of the 9-inch ford axle removable assembly referred to as a Third-member So I would assume the same of the front TTB as that being called a third member. Not sure what else to call that thing.
Old Aug 5, 2008 | 04:46 PM
danr1's Avatar
danr1
Yea the nine has always been called a third member as long as I can remember. The front as a separate "unit" it could be called that too I guess, different animal though.
When I read it I completely read over the fact it was the front and assumed it was a rear 8.8? he was working on.
Old Aug 5, 2008 | 07:53 PM
shadowf150's Avatar
shadowf150
well if it makes it easier for everyone to understand i will use girl language. like my sister uses. ..." You know that thing inside the big thing with the crooked teeth in a big circle stuck to the other thing with the four little round things in side that have teeth on them. yeah that thing .... it wont come out!!!"
shadowf150's Avatar
shadowf150
you know i never thought about pulling the axles out first. i will try that next time.
Old Aug 5, 2008 | 08:01 PM
alz's Avatar
alz
The passenger side axle is held in with a c-clip.
Old Aug 5, 2008 | 08:16 PM
shadowf150's Avatar
shadowf150
yeah thanx alz... the axles where out... the whole thing has been on the bench.
