351W rockers
Old Aug 5, 2008 | 10:07 AM
jklapp86's Avatar
jklapp86
351W rockers
I was looking at possibly buying an intake for my 351 but i was reading that buying higher lift rockers would give me more gains than and intake would for half the price from what i was looking at. My question is what kind of rockers should i be looking for to go into my 94 F150 and at what lift will i have to change out my springs and other various valve train parts?
Old Aug 5, 2008 | 11:12 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
I doubt you'd pick up more that a couple of hp with 1.7 rockers. Crane claims a 20hp increase on the Mustang Cobras that used 1.7 roller rockers, but the cam and computer were different as well.
Old Aug 5, 2008 | 02:01 PM
Conanski's Avatar
Conanski
1.7 rockers are a bolt on upgrade on these motors, no other parts needed, though some oil baffle clearancing may be necessary on the valve covers. Power gains are hard to put numbers on, but in general the more the valves open the more air the motor passes. You'll go from 0.422/0.448" lift to 0.448/0.476 lift, on 351 that should produce a noticable increase across the board.
Old Aug 5, 2008 | 03:17 PM
jklapp86's Avatar
jklapp86
they have all these different types i was looking at on summit (roller tip,pedistal mounted,stud mounted, ect.) what do you have to run on these and whats the diff? also if you put 1.7 rockers in and you dont have to change the springs if you put a mor aggressive camin will you then have to change them out?
Old Aug 5, 2008 | 03:54 PM
Beanscoot's Avatar
Beanscoot
Rocker arms
The bolt on (pedestal mounted) roller rocker arms are simply that- the existing rocker arms are unbolted, then the new ones bolted on.
As Conanski said, "1.7 rockers are a bolt on upgrade on these motors, no other parts needed, though some oil baffle clearancing may be necessary on the valve covers." These are Summit part CRN-44746-16, Crane Energizer Pedestal Mount Roller Rocker Arms.
The stud mounted type require the heads to be removed and machined to accomodate them. Their studs are stronger than the pedestal mounted roller rocker arms' capscrews, but this is moot in most applications since these capscrews seem to be quite strong enough.
The roller tip type have a non-roller fulcrum, so are only half rollerized.
I believe you can use the slightly higher lift Mustang HO cam without changing valve springs. Maybe others can recommend other camshafts that will work.
So far as comparing the installation of bolt on pedestal roller rocker arms to swapping intake manifolds, the former is much simpler and cheaper.
Old Aug 6, 2008 | 07:29 AM
Conanski's Avatar
Conanski
There is no need to upgrade the valve springs with 1.7 rocker arms, but almost certain you would need to with an aftermarket cam.. anything worth upgrading to at least. If you have plans to upgrade the cam soon then either do that instead of rockers or get 1.6 rockers now, the higher ratio rockers will put valve lift into dangerous territory with many aftermarket cams.
Old Aug 6, 2008 | 07:59 AM
jklapp86's Avatar
jklapp86
whats the stock rocker lift? i saw in your sig conaski that you have a cam that you highly rec. i with thinking about that one seeing as its same motor but with the 1.7 rockers you will run into clerance problems? (valve to piston?)
Old Aug 6, 2008 | 08:17 AM
Conanski's Avatar
Conanski
With the Crane 444232 you can use 1.7 rockers.. it's one of the few decent cams left with under 0.500" lift. But... you have a roller motor so this cam would require you change the lifters and pushrods as well which are added expenses and a backwords step. The Comp 35-351-8 would be a good candidate for your motor, matching springs would also be recommended.
Old Aug 6, 2008 | 11:53 AM
jklapp86's Avatar
jklapp86
would a cam give me more of a gain than installing rockers? Ive heard here that when you install a cam you can move the power band up to higher rpm's i would like to keep my power band as low as possible right now.
Old Aug 6, 2008 | 12:37 PM
Conanski's Avatar
Conanski
The 351 will can use some additional duration, it will broaden the powerband without impacting the low end. The F4TE cam in your 94 is well suited to the 5.0 but it strangles the 5.8. It's specs are 422/448 lift and 256/266 duration. The Crane has 448/464 lift and 268/276 duration, and comparing my truck to my fathers stock '95 there is no contest, my truck made more power everywhere. Adding rockers to the stock cam will be a benefit, but it won't be as much as upgrading the cam.
Old Aug 6, 2008 | 01:34 PM
BaronVonAutomatc
Where in the RPM range a cam will develop its power depends on the specs to which it is ground. And there's a lot to cam design beyond duration and lift.
A new cam will give you 20-50 more hp all across the powerband. Different rockers might - MIGHT - give you 5 more hp.
Does your truck have headers and a free-flowing exhaust? If you don't you'd pick up more there than with new rockers.
Old Aug 9, 2008 | 05:46 PM
doug1222556's Avatar
doug1222556
The intake would net you more gain than the rockers. Just thought I'd throw that in since everyone else skipped over that to talk cams.
Old Aug 10, 2008 | 04:38 AM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
Conaski what do you suggest for matching springs?
Also would the 1.7 rockers work well with the crane cam you suggested. 35-351-8
Old Aug 10, 2008 | 10:28 AM
Conanski's Avatar
Conanski
Thr rocker ratio multiplies the cam lift, so no you don't want 1.7 rockers with a 0.512 lift cam. Comp cams has a complete list of matching parts for thier cams in a PDF file on the web site. If you upgrade the springs on the heads you will also need upgraded pushrods, the stock pushrods are simply not up to the job.
Old Aug 10, 2008 | 01:01 PM
Truckin4life
alrighty, thanks for the help!
