No A/C, compressor not engaging
Old Aug 16, 2008 | 01:00 PM
fordtrucklover94's Avatar
fordtrucklover94
Yeah, it's definitely got a leak, I just haven't got any money to take it to a shop, i lead the joyous life of a college kid, scraping by with a part time job. Summer is almost over, and the weather is cooling off, so I'll tough it out with no A/C. Here in a couple months i'm taking it in the shop to have the ball joints worked on, thats a bigger issue than no A/C, so I'll have them check it out then.
Old Aug 16, 2008 | 01:21 PM
marragtop's Avatar
marragtop
To Magician: not sure what year your truck is, but if it's an R12 system, you should convert to R134 since your accumulator and compressor are bad.
Old Oct 15, 2017 | 10:15 PM
Tuff90's Avatar
Tuff90
Originally Posted by jstutz101
Sounds like you might have a leak. I would check to see if there is refrigerant in the system. If the pressure gets low enough the compressor wont kick in.
How do u get the compressor to kick in so u can check freon?
Old Oct 16, 2017 | 06:56 AM
shorod's Avatar
shorod
Welcome to the forum!
Getting the compressor to kick in is not how you check the level of refrigerant. You do that by installing a manifold gauge set to check the pressure in the system. The pressure readings will vary depending on the level of refrigerant in the system.
Forcing the compressor clutch to engage is to confirm the other parts work, such as the compressor clutch field coil, the clutch itself, and the compressor.
-Rod
Chips2000
Apr 2, 2018 04:30 PM
FX4_4x4
Apr 24, 2017 06:39 AM
PasoF450
6.7L Power Stroke Diesel
Mar 5, 2017 04:13 AM
Geohill279
Nov 5, 2016 11:01 AM
kountzecobra
Feb 22, 2016 08:38 AM
