Runtime Error?
Old Aug 4, 2008 | 07:10 AM
1956MarkII's Avatar
1956MarkII
Runtime Error?
My laptop has developed a strange problem. Right in the middle of searching a website a window pops up with "Runtime Error!," and then NOTHING works right: IE shuts down, e-mail fails to respond, and everything closes. If I restart the computer, it's usually OK, but it can occur again after an hour or so.
Did some research and thought maybe having Earthlink Total Access running in the background was the culprit, but I turned it off and the problem still occurs. Couldn't find anything on the web that was really helpful- one company claims to fix it for free, but all their "Download Now!" links just take me to Netflix movies. Anyone else have this occur, and are there any fixes?
Old Aug 4, 2008 | 10:34 AM
donjamer's Avatar
donjamer
Try updating Adobe flash player and Shockwave..
There is probably some embeded script that is being called and your older version doesn't know how to handle it..
Also what version of internet explorer or firefox are you running.. You could try updating that also..
Old Aug 4, 2008 | 12:05 PM
modar's Avatar
modar
if you have vista... open a web page and click on tools, internet options, click on advanced tab, at the bottom of the window click reset.
Old Aug 4, 2008 | 11:24 PM
ford2go's Avatar
ford2go
Have you checked for viruses , spyware and the like?
I use Norton on one compute and AVG on the other. Plus I use Spybot on both. I don't run ad aware -- although I probably should.
One other trick I've used is to create a new account and pull anything I want over there. After a while I get rid of the original account. ( I also usually surf with a non admin account unless I'm doing financial type stuff)
Good luck,
Old Aug 5, 2008 | 09:45 AM
donjamer's Avatar
donjamer
Good luck,
You do not need to run Ad Aware if you are running Spybot.. They are the same type of program and Spybot is 100 times better..
I have worked on many pc's that had ad aware and still got infected..
Old Aug 6, 2008 | 02:51 AM
rebocardo's Avatar
rebocardo
I agree with post #2. The other thing is to check your process list when this happens. A trojan could be trying to load its own corrupt .dll library as the multi-media .dll on your computer. Since the links are bogus, it is crashing Explorer.
Old Aug 6, 2008 | 06:57 AM
mistakenID's Avatar
mistakenID
Laptop might just need a good cleaning. Dust and dirt will make all computers overheat eventually, laptops are worse.
Computer starts to get dirty, use it for a while, it gets hot, get errors and shutdown.
cjben
Dec 1, 2012 10:09 AM
wlihntr
Sep 2, 2007 08:48 AM
1956MarkII
Mar 18, 2007 10:37 PM
Fordlover55
Apr 12, 2005 02:59 PM
99 ranger bob
27
Apr 6, 2004 10:11 AM
