supercharging a 400?
Old Aug 3, 2008 | 12:04 PM
JBradley500's Avatar
JBradley500
has anyone used a centrifugal supercharger on a 400? i was wondering what would be involved in this and possible cost. using 5-8 pounds of boost probably. im not very serious about doing this right now, but maybe if i get bored and have some money laying around...you never know.
Old Aug 3, 2008 | 02:34 PM
Goose_52's Avatar
Goose_52
I havent seen any superchargers for 400's, but you could find one for a Cleveland and use the intake adaptor plates.
Old Aug 3, 2008 | 06:54 PM
JBradley500
i see that make roots style, but id like to keep it as low profile as possible, telling everyone its a stock 351m. lol.
Old Aug 3, 2008 | 07:10 PM
danlee's Avatar
danlee
Have you looked at Procharger?
ProCharger Self-contained Superchargers and Intercooled Supercharging Systems
They have a blow through setup that could be fitted onto a 400 with a 4 barrel carb. Unfortunatly they don't show any brackets for a 351C or 351M/400 motor. It would be worth a call or email.
Old Aug 3, 2008 | 07:46 PM
73XAFalcon's Avatar
73XAFalcon
If you are willing to fab your own brackets, you can bolt a centrifical blow-through set up on just about anything. I've seen Vortechs & Paxtons bolted onto Ford I6s, flatheads, one 2.3 I4, 225 slant-6, Chevy 2.8 V6, and even a Capri 2.6 V6. MSD and Mallory ignition boxes will support a blower on a 400. There are several companies that sell carb hats and both Holley and Demon will sell you a carb modified for blow-through applications.
Old Aug 3, 2008 | 08:55 PM
JBradley500
i requested a catalog, just for reference. it would be nice to have 500hp or maybe a little more with the boost. theres no real good reason to, just to actually have it and see how many 350 guys will say they have about that too with their double hump heads and a thumpr cam or whatever they have BS about.
Old Aug 3, 2008 | 10:03 PM
hollenjoe's Avatar
hollenjoe
You dont need a supercharger to get a 500hp 400, i estimate with chi aluminium 2v heads and 10.6:1 my built will make 500hp at 6k and 500lbs of torque at 4500rpm with stump pùlling power from idle to 6k.... so instead of a supercharger why not some pair of heads like the chi2v or even a stroker 434 kit?
Old Aug 4, 2008 | 06:08 AM
danlee's Avatar
danlee
Log onto this group and post your question. If anyone has done it, someone in this group will know about it.
351ClevelandsRock302C351C351Boss351HO400 : 351 Clevelands Rock!!! Ford's "BIG" smal
Old Aug 4, 2008 | 11:50 AM
Behemoth's Avatar
Behemoth
Maybe I'm wrong, but wouldn't a centrigual charger not give you the full benefits of that particular power adder? My point is, with the 400 being a fairly low RPM engine, and centrifugals producing more boost the higher the RPM's, it seems like you might not ever reach the chargers full output capacity, regardless of the pulley. Maybe if you ran a 8lb pulley, but still kept the RPM's under 4500, my theory is you'd probably be running more like you would if you had something like a 5lb pulley. Anyway, it's just my theory.
When I was looking at chargers for my Lincoln project, the Kenne Bell supercharger caught my attention as it achieves max boost at 1800 rpm, and stays so throughout the band. I'd figure with our engine characteristics, that's not a bad way to go if they had an application for it. I don't think they have one for our intakes, though.
The idea of a supercharger on a 400 is an interesting concept, though. Myself, I won't be doing it as between the CHI heads and the stroker kit, as well as the headers, carb, cam, etc, etc, etc., I figure I'll have more than enough grunt for my needs.
Old Aug 4, 2008 | 07:15 PM
JBradley500
im not saying i plan on doing it, i was just interested in it and seeing if its been done. i see theres a stock 400 with a turbo on youtube. i just though supercharging may have been done before.
Old Aug 4, 2008 | 07:55 PM
danlee's Avatar
danlee
I think that a Turbo will run better on a 400 motor with lots of low RPM torque. The turbo will move the air at the High RPM area when a large cube motor can't get enough air. It's CFM that's required at high RPM, not 'boost'. If you can't feed enough air the boost will drop quickly.
Old Aug 8, 2008 | 11:50 AM
mustang81's Avatar
mustang81
JBradley500, i post a few month ago for a blower. BDS. Blower drive service have a blower for 400 for arround 4200 $. make a search for ( blower for 400 ) and visit Welcome to Black Diamond Software, Inc.
Old Aug 8, 2008 | 11:52 AM
mustang81's Avatar
mustang81
I only type bsd and black diamond software appear???
Old Aug 8, 2008 | 01:49 PM
73XAFalcon's Avatar
73XAFalcon
I think you wanted to type:
Blower Drive Service: We Deliver Horse Power! - Blower Drive Systems, Blower Kits, Blower Cams, Custom Carb Service
Old Aug 8, 2008 | 02:16 PM
Behemoth's Avatar
Behemoth
I think they were talking about blowers that would fit underhood. Those big ones like BDS, Weiand, and Dyer's are all tall enough to cause the need for cutting the hood, which is what it seemed they wanted to avoid. Typically the one's for that issue would be centrifugal, but I remember having seen a roots type blower that was mounted as an accessory low on the engine, and plumbed to the intake....but it also required a conversion to EFI.
62bugman
Ford Truck Parts for Sale
Mar 1, 2018 07:05 PM
jshanematthews
16
Jul 25, 2013 02:56 PM
A1C DiMaggio
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Oct 30, 2010 09:54 PM
A1C DiMaggio
Oct 30, 2010 03:29 PM
kilbrethj
Jul 4, 2007 07:10 PM
