reverse lights not working...HELP
Old Jul 26, 2002 | 07:32 PM
blueoval79's Avatar
blueoval79
My reverse lights are not working. I replaced the bulbs and to no avail. My passenger side rear tailight won't light up with the headlights on, but will when i press down on the brake with the headlights off. WHAT IS WITH THIS!!!! It's a 79 F250 by the way. Any help would be appreciated.
Old Jul 26, 2002 | 11:18 PM
Mil1ion's Avatar
Mil1ion
You have a bulb in the socket in the wrong position.
Check it out for the offset nubs on the bulb.
The backup light switch is incorporated into the neutral safety switch on the side of the transmission.
Maybe read some other posts directly below this one for what to do.
I have answered many of these the last few days.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Jul 26, 2002 | 11:20 PM
Mil1ion's Avatar
Mil1ion
Old Jul 26, 2002 | 11:34 PM
blueoval79's Avatar
blueoval79
could the reason the back up lights aren't working because the washer fluid ain't spraying out either. What i mean is could it be a fuse?
Old Jul 27, 2002 | 08:59 PM
Luis_3's Avatar
Luis_3
I think you have a fuse problem.
I also had same trouble and located under hood drivers side there´s a box with fuses. One there was not ok.
Old Jul 27, 2002 | 09:33 PM
Mil1ion's Avatar
Mil1ion
The fuse box on a 79 is on the inside firewall near the left vent.
The neutral safety switch/backup switch are incorporated and attached to the side of the tranny.
You can do the 12V jumper wire to the harness to bypass theswitch to see if the lights come on.
[/font]
[/font]
Old Aug 10, 2002 | 07:42 PM
shaker666's Avatar
shaker666
Post reverse lights not working...HELP
I just moved to Vancouver, BC from Tucson, AZ. I've got a '79 Bronco Ranger XLT and I've rebuilt the whole thing except for the transfer case and transmission. In order to pass inspection in this province (reqd. to get insurance), I need to ensure that all of my lights are in working order. To my knowledge, I've never seen my reverse lights work. I know there's good bulbs in there and I'm pretty sure the truck doesn't start when the trans is set to Drive.
Is the reverse light switch a separate unit from the neutral safety switch, or is it integral to it? What else might I look at to solve this problem? Any ideas are appreciated.
epoppe4
Feb 19, 2015 07:49 PM
powerstroke79
Nov 1, 2013 07:58 AM
mthorlakson
2004 - 2008 F150
Mar 22, 2013 02:43 PM
ChrisLambert
Electrical Systems/Wiring
Jul 9, 2004 01:56 PM
brian's79ford
15
Apr 28, 2004 09:23 AM
