Electrical question
Old Aug 1, 2008 | 11:02 PM
4X4XFar's Avatar
4X4XFar
Electrical question
I was installing a mega-third brake light on my 2005 F150 SCREW. I have blown something because now I have no dome lights, instrument cluster, power windows, or stereo. I have checked nearly all of the fuses (I tried to figure out which ones would be related).
Is there anything else I should be checking?
Thanks much in advance.
Old Aug 1, 2008 | 11:16 PM
96sherm's Avatar
96sherm
if all the fuses are ok, it must be a relay under the hood... get out the manual, start reading... does the truck start and run ok??
Old Aug 1, 2008 | 11:20 PM
4X4XFar's Avatar
4X4XFar
Yes it starts and runs great.
Old Aug 1, 2008 | 11:21 PM
96sherm's Avatar
96sherm
there'll be a relay that controls the interior electrical system i think... happy searching...
Old Aug 1, 2008 | 11:24 PM
4X4XFar's Avatar
4X4XFar
Thanks for the direction!!
Old Aug 2, 2008 | 10:38 AM
Slvr 2008 SS SC's Avatar
Slvr 2008 SS SC
You had mentioned that you checked the fuses, did you test them with a meter or just did a visual check. I the past I've looked at the fuses and then when I tested them with a meter found some to be open.
turbo930ss
13
May 17, 2013 12:36 PM
Larzon
Nov 18, 2012 06:56 PM
nunboutmuch
Electrical Systems/Wiring
Jul 24, 2009 11:31 PM
eminence80
Jun 19, 2006 01:06 PM
bmxerbrett
Jan 29, 2006 08:07 PM
