6637 Filter ?
Old Aug 2, 2008 | 08:19 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I used a 3" DWV-PVC coupling to install mine. I used a die grinder to knock off a little bur on the outside of the coupling and the ridge on the inside of it. Fit great, no problems. Here is a pic of the filter with Pete's cover on it.
Old Aug 2, 2008 | 08:28 AM
Mid_Mo_F100's Avatar
Mid_Mo_F100
I clamped mine right to the filter(no pipe) and so far no problems. I roughed up the filter with sandpaper to give the stock boot a little more gription on the filter, and then put a bead of black silicone(outside not inside) around the end of the stock air boot for a little more holding power and to use as a gauge for movement. It did take some patience to squeeze the stock boot over the filter though.
Old Aug 2, 2008 | 08:37 AM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Originally Posted by STROKER350
Markadeck that would be great if you could post a pic so I cqan see how it's done.
This is it with the OEM clamp and about 6000 miles on what's now my 4th filter since the installation over 2 years ago and it's never moved one iota.
Old Aug 2, 2008 | 08:41 PM
STROKER350's Avatar
STROKER350
Thanks everyone for the info. I did mine the ol' fashioned way with the 4" section of 4" pipe (ground off the burrs). Something I did to make the filter fit in the tight space a little better was move the battery box toward the front. There is an extra hole in front of the hole the factory mounted the box to. Just thought some people might want to know this, now the filter goes on down in the space where the old air box was easier.
Old Aug 2, 2008 | 08:56 PM
miller_feed
I didn't know that, Mine fits fine the way it is. But you may have something new.
Old Aug 2, 2008 | 11:42 PM
superduty4x4's Avatar
superduty4x4
I'll have to check into this, thanks for the info.
Old Aug 4, 2008 | 02:27 PM
STROKER350's Avatar
STROKER350
Nice cover!! Where do you get them?
Old Aug 4, 2008 | 02:40 PM
superduty4x4
We buy our covers from Pete, aka F250_ Shoot him an email at filtercovers at gmail dot com
Old Aug 4, 2008 | 03:36 PM
King0581's Avatar
King0581
Next time I change my filter I just might check into this. I had to cut my previous filter off the 4" pipe to get it off.
1buckeyefan
Mar 29, 2011 11:17 AM
mh5500
Jan 24, 2008 09:09 PM
jimandmandy
Sep 14, 2002 07:43 AM
Justin89
Aug 16, 2002 05:31 AM
acogoff
May 6, 2002 04:31 PM
