What would your first Mod Be?
Old Aug 1, 2008 | 07:19 AM
flaboy63's Avatar
flaboy63
What is the first mod everyone would do? That will make the most difference. I just got an I/C but thats later,
Old Aug 1, 2008 | 07:49 AM
ron86toy's Avatar
ron86toy
Well...it should be intake or exhaust....I think I did the 6637 mod first.
Old Aug 1, 2008 | 08:16 AM
93f1505.0L's Avatar
93f1505.0L
Guages!!! well that woud be the right thing to do but I had Intake, Exhaust and Tunes first but you have to be able to watch everything when you start modding.
Old Aug 1, 2008 | 09:24 AM
c00nhunterjoe's Avatar
c00nhunterjoe
i think if you have a bone stock truck then the first mod should be the air filter.
my reasoning is because the stock airbox allows so much dirt to get past that in order to prolong the life of your motor you need to change it. also in a close second is the removal of the orange intake boot. after those 2 things then do the downpipe and exhaust.
Old Aug 1, 2008 | 09:52 AM
flaboy63's Avatar
flaboy63
Joe give me a lesson on the orange intake boot.where is it the one that hooks up to the turbo. What do I replace it with?
Old Aug 1, 2008 | 12:39 PM
secondarychaos's Avatar
secondarychaos
X2 on the boot question...
i would say (and i did) gauges first. that way you get to know your truck a little better and see what's going on. also they're needed for future mods to be seen instead of just felt
Old Aug 1, 2008 | 12:49 PM
c00nhunterjoe
the orange intake boot is easily replaced with the superduty boot, you also have to get rid of your aluminum 45 degree crankcase vent adapter and use the straight one off the superduty, or just eliminate it all together and do the ccv mod at the same time.
this is not the best picture, actualy its a really old one of under my hood, but you can see the superduty black intake at the turbo and the black ccv adapter.
Old Aug 1, 2008 | 02:01 PM
secondarychaos
Ok, so why does it need to be replaced?
Old Aug 1, 2008 | 02:09 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
this gave you a better idea:
you also can use this as a direct replacement:
Ford Powerstroke: Intake Hoses, IntakeTubing, and Intake Clamps
and read this link:
https://www.ford-trucks.com/forums/6...fuel-leak.html
BTW the first mod you shoud do is mod your walet
Old Aug 1, 2008 | 02:11 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Bad quality, tends to colaps and can get a little hole in it.
Old Aug 1, 2008 | 02:12 PM
secondarychaos
and read this link:
Thanks! that was a good link.
Is the mod to the wallet to have it holding more or to have it prepared to be emptied???
Old Aug 1, 2008 | 02:28 PM
Copedawg's Avatar
Copedawg
whoa whoa.....what am I looking at here??
What are the 2 pipes comng from above the little orang boots? and where do they lead to????
Old Aug 1, 2008 | 02:33 PM
Zookie400's Avatar
Zookie400
my first mod would be the down pipe. i gained 2 mpg when i did mine.
Old Aug 1, 2008 | 06:43 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
No problem. BE prepared to empty it very soon. LOL.
I think you are refering to the intercooler pipes.
Old Aug 1, 2008 | 06:50 PM
superduty4x4's Avatar
superduty4x4
Those are intercooler pipes, they go to the intercooler which was stock on SD's but not OBS trucks.
My first mod was 6637 intake w/ CCV mod, then 4" exhaust, then gauges. In with the good air, out with the bad air, then monitor your truck better. Once those are done you are set up pretty good for other mods (chip, injectors, big oil, etc etc.)
justin_h
Jun 26, 2015 08:15 PM
USMC0351fordtruckin
Apr 23, 2013 09:04 AM
BigD7575
Mar 3, 2008 10:01 PM
1966ford
1983 - 2012 Ranger & B-Series
Dec 15, 2002 10:58 PM
jpruett1
Nov 13, 2000 12:47 PM
