Sponsored by: Real Truck
Wiper issues....They don't work!
Old Jul 31, 2008 | 07:16 PM
BillyBob69's Avatar
BillyBob69
Well since I bought my motorcycle, I have been driving my SD only about once a week. Well since last Friday and today...it has been sitting...but I went to drive it today and no wipers. No clicking, groaning, twitching or cussing except for me. I checked the fuse under the dash and it is fine, and found it to be the same fuse for the washer fluid pump. Well that works. I also checked the Maxi fuse under the hood in the PJB and that is fine....at least by visual inspection. So what should I check next? Fuses are good, washer pump works, wipers don't.
Thoughts?
Old Jul 31, 2008 | 07:23 PM
ReAX's Avatar
ReAX
Try turning them on and working the arms manually. You might feel the motor working, but not moving the arms on it's own. Then I would check for voltages at the motor with a DMM. If the motor isn't being powered, I would look at the GEM next.
Old Jul 31, 2008 | 08:13 PM
BillyBob69's Avatar
BillyBob69
OK Tired the moving the arms with the switch on...nuttin
Well since I have to pull the cowel to get to the connectors...the voltage testing will have to wait until tomorrow. I need a new battery for my DMM.
Old Jul 31, 2008 | 08:45 PM
BillyBob69's Avatar
BillyBob69
I unplugged the top two connectors on the GEM...plugged em back in in hopes of resetting it....nothing.....UGH!!!
Old Aug 1, 2008 | 10:55 AM
redford's Avatar
redford
FTE Leadership Emeritus
This may sound stupid, but try turning your wipers on when the switch is in the high beam position.
I had a multifunction switch fail, the wipers would only work when the headlights were on high beam. Made it real hard to drive when it rained at night unless I left the high beams on and ignored the other cars.
Old Aug 4, 2008 | 03:16 PM
BillyBob69's Avatar
BillyBob69
Well the rain is coming....so I need to get this fixed quick....the local dealer wants an arm and a leg for either the MFS or the GEM. Any other places to get it without taking out a loan?
Old Aug 4, 2008 | 03:40 PM
ReAX's Avatar
ReAX
Not really, you could try a junkyard GEM or MFS, but there isn't any guaranty that it will function correctly.
Old Aug 4, 2008 | 04:07 PM
dkf's Avatar
dkf
I recently paid $100 for a Multi-function switch. Not really an arm and a leg in my book. A dealer will charge $100 just to look at the truck.
Old Aug 4, 2008 | 05:17 PM
krewat's Avatar
krewat
MFS is definitely available aftermarket - or at least, in an aftermarket box with a Ford logo on the part
I'd still check for voltage at the motor - otherwise you're just guessing.
Old Aug 4, 2008 | 09:13 PM
high ho silver's Avatar
high ho silver
Thoughts?
Look for signs of infestation since it has been sitting a while.. Mice love to bed down in the most odd places and then chew on stuff.
Old Aug 12, 2008 | 02:42 PM
BillyBob69's Avatar
BillyBob69
Well now here is something interesting.....So I traced the wiring...no wear spots, no rodents chewing on it...nothing...all looked normal. Just not getting power to the motors....I checked the harness in the steering column, checks OK....Well I ran out of time so I had to leave it for the night...the next morning, I guess I had left the switch to the ON position....but on my way to work..I hit a bump and they start working again. I had checked all the connections...and this didn't happen until AFTER I had left the gravel road and was on paved road for about 10 minutes...wierd.
Old Aug 12, 2008 | 04:18 PM
Monster-4's Avatar
Monster-4
You know the old saying that if you can't get something to work the first time get a bigger hammer.
Old Aug 12, 2008 | 04:28 PM
BillyBob69's Avatar
BillyBob69
LOL!! I did think about that! Had a buddy that used to have an old MGB. The lights didn't work until jokingly I hit the fender then one tail light came on. So I hit the other fender and that one came on....we spent about 20 mintues hitting the fenders and all the lights were finally working.
Old Aug 12, 2008 | 04:45 PM
redford's Avatar
redford
English cars have electrical systems made by Lucas, Prince of Darkness.
Old Aug 12, 2008 | 04:58 PM
zx250's Avatar
zx250
Of the next Riffraff East
Did you check the relays under the hood? Numbers 34 and 35.
