Sponsored by: Real Truck
Wiper issues....They don't work!
Old Sep 15, 2008 | 09:56 AM
BillyBob69's Avatar
BillyBob69
OK latest ghost....so the wipers worked fine until about a week ago...then it was raining and they were on but I could see they were slowing down and a weird sound seemed to be coming from the motor....finally they quit working....and now they will only work in the HIGH position. If I turn the switch back, they stop right where they are. I have to time it so they stop at the bottom. OK switch or motor?
Old Sep 15, 2008 | 10:08 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
If they don't return "home" when you shut them off, that's probably the motor. I say "probably" because anything is possible. If the motor doesn't have power to the "home" switch, well, it won't "home" either
Old Sep 15, 2008 | 10:14 AM
krewat's Avatar
krewat
I've been looking at the schematic for my '01, I'm assuming they are somewhat the same.
There are two relays, a "run/park" and a "high/low" relay. And everything is controlled by the GEM.
Do you have any water on the floor on the passenger side?
Old Sep 15, 2008 | 10:22 AM
BillyBob69's Avatar
BillyBob69
Nope...no water/leaks. This all started after I let her sit for about a week. I left my 2way radio on in the truck so I had to jump start it...reset all the stereo settings etc...Then went to spray and wipe the dust off the windshield and thats when I first found the wipers not working.
