Sponsored by: Real Truck
trailer capacity
Old Sep 14, 2008 | 10:57 AM
edub32's Avatar
edub32
trailer capacity
what do you guys think the capacity is of this trailer is just by looking at it?
Old Sep 14, 2008 | 11:09 AM
dkf's Avatar
dkf
Depends on the what the axles and tires are rated at. I'd suspect it is at least a 6klb GVW trailer. The trailer itself probably weighs around 1400lbs or so.
Old Sep 14, 2008 | 11:12 AM
senix's Avatar
senix
I would agree, enough to fit a small/mid size car on it. You can always get the trailer weighed to check that. might also want to check the load rating on the tongue if it is stamped and check the rating on the tires too.
Old Sep 14, 2008 | 11:45 AM
edub32's Avatar
edub32
yeah the guy did tow a car with it. do you think i would be good to tow a 5300 lb tractor on it?
Old Sep 14, 2008 | 12:17 PM
senix's Avatar
senix
Based upon what I can tell, I think so, I would be watching it as you put it on there. Just a short drive should be ok, wouldn't go accross the country with it.
Old Sep 14, 2008 | 01:19 PM
skip mitchell's Avatar
skip mitchell
I would suspect just looking at it it has 15" tires and each axel would be 3500 lbs each or 7000 lbs gross weight.
Old Sep 14, 2008 | 07:28 PM
banditsdaddy's Avatar
banditsdaddy
Like Dkf said, check the capacity of the tires and if it is an old trailer and the tires are cracking you might consider replacing them before going to far. Generally 5 years is the safe limit on trailer tires.
Old Sep 14, 2008 | 08:24 PM
heymrdj's Avatar
heymrdj
I think it's just barely capable of that weight tractor but as a previous poster stated, short distances, ie under 20 miles one way if you ask me. I don't think it would hole up well to punching it 65mph down the highway with that load.
Old Sep 15, 2008 | 07:22 AM
banditsdaddy
Does your tractor weigh 5300 without any attachments and without liquid in the tires to give it extra weight for traction?
Old Sep 15, 2008 | 11:38 AM
rdollie's Avatar
rdollie
How many axles on that trailer have brakes?
