What size bolt?
Old Jul 31, 2008 | 11:54 AM
Farmboypowerstroke's Avatar
Farmboypowerstroke
What size bolt?
i'm dropping my fuel tank, and can't seem to find the right size socket. What size is it? 1/2 too small,9/16 to big, 14mm too big. 13mm to small. ???????
Old Jul 31, 2008 | 12:37 PM
Farmboypowerstroke
can i just take the 2 bolts out on one side? instead of all 4?
Old Jul 31, 2008 | 12:41 PM
guitarpicr's Avatar
guitarpicr
Yea - You can just take 2 out and pivot the brackets back- Cant remember the size of the bolts, but they werent anything out of the ordinary, unless the heads are stripped.
Old Jul 31, 2008 | 02:14 PM
Farmboypowerstroke
ok i got 13mm on the bolt heads. once i get the tank down, and if there is any crap at the bottom what is the best way to get it out?
Old Jul 31, 2008 | 04:26 PM
nlemerise's Avatar
nlemerise
I assume you will be removing the ring and the float assembly? Then just reach inside with a rag and clean it up (if I remember correctly). If you got arms like Popeye after spinach, get some kid to do it for you...spring for a sodie pop.
Old Jul 31, 2008 | 06:53 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Shop vac maybe?
Old Jul 31, 2008 | 07:43 PM
danskool's Avatar
danskool
Go Bills !
That was good.
I second the shop vac. I'm doing mine next week and i think that it would work good. Then, I might save what it gets out to use to start bomb fires.
Old Jul 31, 2008 | 10:11 PM
guitarpicr's Avatar
guitarpicr
I was shocked when I did my in tanks aty how clean the inside of the tank was - Hope you find the same. Let us know and good luck
Old Aug 1, 2008 | 05:32 AM
Farmboypowerstroke
I hope its nice and clean. i'll know today.
carlsson
Dec 7, 2011 05:49 PM
xluckyxbulletsx
New Member Introductions
Feb 10, 2009 08:46 PM
lionsteve
May 24, 2007 05:07 PM
jaycrow
1983 - 2012 Ranger & B-Series
Aug 31, 2003 08:57 PM
