Opinion or Performance?
Old Jul 31, 2008 | 06:52 AM
DemonRace6's Avatar
DemonRace6
Hi!
I have been saving up to complete three main things in my truck, 6637, exhaust, and chip.
I got the 6637 but with diesel prices it is not easy saving for the other two. So I have decided to convert my truck to WVO. For this I will need two gauges, Veg Oil Temp, and Veg Oil Level.
My question: If I get the four gauge pillar I will only have two extra pods, and I wanted the three “standard” gauges with theses mods; Trans temp, EGT’s, and boost. But I cant, and I don’t really want gauges all over my truck, so what two are the best to have?
Still learning here so thanks!
Old Jul 31, 2008 | 07:34 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
If I had to choose only two, I would go with trans and EGT. Boost is good to have but the other two can really hurt you more.
Old Jul 31, 2008 | 07:38 AM
HKusp's Avatar
HKusp
If you aren't going to chip it, like Rick said, forget about boost. It will only max out at 16psi probably and will be well within the safety limits of the truck. The other two gauges monitor much more important things.
Old Jul 31, 2008 | 07:48 AM
mueckster's Avatar
mueckster
You could add some more gauge pods and put the WVO gauges there. Such as these: 99-03 7.3L Gauge Mounts
Old Jul 31, 2008 | 09:07 AM
jeff7825's Avatar
jeff7825
You could do the three pillar pod and then do the under dash pod. Just a thought.
Old Aug 1, 2008 | 08:50 AM
DemonRace6's Avatar
DemonRace6
Hi!
I am definitely planning on chipping it, I just have to save up a bit. So if boost is the least to worry about I will probably not get that gauge.
I don’t think I want gauges all over the truck like I see some ricer burners, although if I need all of them to keep the truck save I would do it. But I think I"m just going to go for the four gauge pillar pod.
