I have an 06 F-250. I was trying to replace the bulbs but the screw was a odd size. a 6mm was too big but a 5mm was too small, and a 3/16 was too small but a 1/4 was too big. What do i need to get to take the nut screw out. Cant get plyers or needle noses to it, not a big enough crack.
Try posting your question on one of the sites tech forums. The members there will be able to assist you with your problem.
Check out the local Ford owners in the NC chapter of FTE here,,,, https://www.ford-trucks.com/forums/forum88/ Introduce yourself and most important JOIN your local chapter.
