C6 Issues
Old Aug 18, 2008 | 09:25 AM
campinnut's Avatar
campinnut
Could this also cause the truck to not go foward at all???Only reverse???
Old Aug 18, 2008 | 03:14 PM
Tedybear's Avatar
Tedybear
Different set of issues in play for that problem Campinnut.
Loss of forward is caused by several different possible issues.
For example, if you can put the truck into manual first gear, and it takes off normally? That would point right to the one way roller clutch being bad. That same part is also used for reverse---so it's not that likely to be the cause.
Bad bands/clutch pack....pressure issue...gummed up valve body..etc..
It's worth a shot to start your own thread onto the problems you are having, we will do our best to lend a hand with figuring it out.
S-
Old Aug 18, 2008 | 03:29 PM
campinnut's Avatar
campinnut
I decided to have it rebuilt. I called several transmission places in my area and got a quote of 1,300 for rebuilding mine. So i figured it was a good price.
Old Aug 18, 2008 | 05:02 PM
Tedybear's Avatar
Tedybear
That's about par for the course for a rebuild. Just be sure they install and use a new/rebuilt torque converter. I've seen some shops just flush out the old one--
Main problem with re-using the old one? All that sludge that gummed up the system in the first place, gets pumped around the TC. And it does have internal parts that do wear out. In general it might be a good idea to replace it at the same time it's rebuilt. They normally run about $85-$100. It's good insurance, plus the input seal at the pump? Normally cuts into the flange of the torque converter over time. They do make "Sleeves" that can solve that problem, but why bother taking a chance?
S-
Old Aug 18, 2008 | 07:55 PM
campinnut's Avatar
campinnut
The price includes changing the converter. That's what they told me.
Old Aug 18, 2008 | 08:02 PM
Tedybear's Avatar
Tedybear
Sounds reasonable to me then. Keep all receipts and warranty information for future use, just in case....
S-
Old Sep 8, 2008 | 10:18 PM
Katmandu's Avatar
Katmandu
Question
Originally Posted by magusjinx
Could this also apply to A c6 on a 6.9l in an '86 f250? Mine shifts around 2500+ and shifts hard ...
I just bought and 86 F250 w/6.9L diesel tonight and have the SAME issue.
How difficult is it to change out a vacuum pump on a 6.9 ?
Old Sep 9, 2008 | 04:14 AM
tjc transport's Avatar
tjc transport
i ain't rite
very easy. but check vacuum first. you need at least 17 inches for the trans to work properly. and also check all the vacuum lines for leaks.
morganid
May 28, 2012 07:36 PM
K8's Ford
13
Oct 19, 2010 05:39 PM
pzmotorsports
Jul 24, 2009 09:39 PM
dfmatt
Apr 6, 2009 09:24 AM
Tees77f150
32
Dec 26, 2008 11:00 PM
