longevity ???
Old Aug 1, 2008 | 11:59 AM
ron's power stroke's Avatar
ron's power stroke
Originally Posted by rivrrunner
203k and I have worked/hauled with this truck since I bought it new.....w/ 10k on it....yeah I have PMS but it only started after one of my kids graduated and I had a few more $$$ and a lot more time on my hands
WITH OUT A DOUBT Dp tuner was the most bang for the buck....tranny, 2 sets of rotors and pads....other misc stuff but all in all a great truck.
had synthetics in every thing since around 100k
Ron: when is that 17* hpop goin in ????....just got mine, waitin on you man.lol
lol why me?? every time i get the cash for o rigs and gaskets..some thing else takes it...right now i just sat down for a break...putting in up pipes this weekend... i am in hopes to do the HPOP in a couple more weeks...got my finger's crossed....
Old Aug 1, 2008 | 12:03 PM
rivrrunner's Avatar
rivrrunner
nuthin personal man, been gone for most of summer in AK... havn't had acces...but came home to 17* HPOP in box and saw that you had your "still waitin" in your sig....
Old Aug 1, 2008 | 12:10 PM
ron's power stroke
wasnt taking it personal.... glad to see ya back...let me know how the install goes lol.... i want to do the PCM at the same time..but that means no DP for a few days. got to see what the funds let me do...
Old Aug 1, 2008 | 12:43 PM
SpringerPop's Avatar
SpringerPop
My primary emphasis is on longevity. I feel additional filtration gets me the best bang for my buck.
My next filter will be a hydraulic system filter (power steering and hydroboost). That should leave just brake fluid and differential oil unfiltered. Those I can change out every two years, anyway.
As I never tow "heavy", I don't need additional horsepower, so no tuner.
If I were going to add anything, it would be a 6-oh trans cooler.
Maintenance, maintenance, maintenance. Even if I'm just "tinkering" with it....
Pop
Old Aug 1, 2008 | 03:10 PM
Chuck U&R's Avatar
Chuck U&R
Just got home from work and found a BIG BOX on the porch with MBRP on it.
Opened it up and it looks like new ducting for the HVAC. LOL !
Got the trans cooler too !
Now I just need some time off for fun work instead of work work.
Old Aug 1, 2008 | 04:50 PM
aklim's Avatar
aklim
Originally Posted by Aussie Jones
I realise the ww is for the turbo, just unsure of which (engine or turbo) life is extended.
Would it be wirth me ordering one (superchips with 'tow safe' mode installed), as I am about to replace the pedestal o-rings. Does it give any performance benefit?
BTW, why are you up so late/early?
If your turbo is surging, the WW helps the surge and extends the life of the turbo.
Talk to DP TUNER and you can forget the superchips.
Old Aug 1, 2008 | 07:45 PM
parkland's Avatar
parkland
The wicked wheel, while awesome, produces a little less boost, which would mean a little more EGT's. (I think I'm correct on this one)
If you are pushing the truck into dangerous EGT's already, you may need a better turbo, or another means of cutting EGT's such as water injection..
Old Aug 1, 2008 | 07:55 PM
ron's power stroke
The Wicked Wheel<SUP>®</SUP> will:
  • Reduce or Eliminate Turbo Flutter/Surge in your 1994-2003 7.3L Ford Powerstroke.
  • Lower Exhaust Temperatures - NOT increase them
  • Increase Low-End Throttle Response - you may "feel" like your truck has more HP, but it DOES NOT
  • For use in 1994- 2003 7.3L Ford Powerstrokes
  • Is NOT intended as a horsepower mod.
The Wicked Wheel<SUP>®</SUP> will NOT:
  • Increase your performance
  • Increase your truck's horsepower
  • Increase or decrease boost
  • Increase or decrease fuel economy
if it raises ERT's..my pyro didn't show it..
Old Aug 1, 2008 | 07:57 PM
parkland's Avatar
parkland
I thought the WW gave lower boost than stock, and I assumed that lower boost #'s would mean higher EGT's
Mabye only at WOT?
Old Aug 1, 2008 | 08:29 PM
OTTOMATIC's Avatar
OTTOMATIC
I always use a diesel fuel additive. Change oil every 4,000 along with filter. Fuel filter every 12,000. New serpentine belt every 50,000. Rear end ,transfer, front end , change every 80,000 with synthetic. Antifreeze every 100,000 but add anticavitation additive every 50,000. Power steering fluid change every 1000,000 with synthetic. ADD A CHIP AND A FREEFLOW EXHAUST. Crawl undr truck once a week and inspect, Chek everything oil and other fluids once a week. Never let idle never wait for glow plugs, Wind the pi$$ out of it and NEVER lug.
I posted this on another website Best Strategies -Preventative Maint for Diesels ? - Bob Is The Oil Guy
It worked well for me on my 86 6.9 (it was stolen with 456,000 mi on it)
It is still working with my 99 psd. it has original glow plugs and relay. , injectors, u-joints,repairs have been minimal .
I don't like to re-engineer things or mess with something that ain't broke
Old Aug 1, 2008 | 08:34 PM
parkland's Avatar
parkland
The top of the air intake, is a supplemental air heater, installed for the purpose of heating the air during extended idling, to prevent wet stacking.
Where I live, if you dont wait for glow plugs, you aint goin anywhere.
Old Aug 2, 2008 | 04:22 AM
ron's power stroke
Mabye only at WOT?
it spools quicker...less heat to spin it...i guess up top..out of its range it would heat more...but in my 80E im still pegging 27 lb of boost red line hooked...from a dead stop mashing the go peddle ill get well over 100 MHP before i hit 1200 on EGT'S and she dont surge....
