E4OD vs C6
Old Jul 29, 2008 | 09:32 PM
windsor94's Avatar
windsor94
E4OD vs C6
pros and cons of each or why one is better than the other
Old Jul 29, 2008 | 09:43 PM
60F100's Avatar
60F100
As I understand it, the E4OD is based on the C6. It is probably just as strong as the C6 and it has an overdrive thus better overall fuel economy.
Old Jul 29, 2008 | 10:16 PM
Conanski's Avatar
Conanski
Pros and cons here are pretty obvious... The E4OD has another gear the C6 doesn't have, but it's also computer controled and more complicated to install in a non factory equiped vehicle. There's no way to say if one is stronger than the other, it depends what vehicle the trannys came from and if they have any updates or performance modifications. Either can be built up to handle just about any power level.
Old Jul 30, 2008 | 12:39 AM
gweeds's Avatar
gweeds
E4OD is heavier...
Old Jul 30, 2008 | 02:07 AM
Mtthwvn73's Avatar
Mtthwvn73
I've had both, and the E40D seems like it doesn't have the "drag" the C6 had. Both had the same engine (only difference is one was MAF and other SD...but both stock). My old bronco with the C6 and 351 was a slug...felt like it had no power at all, but the E40D and 351 in my truck now will flat get up and go, It makes my 4WD truck feel light.
I don't know if it's true or not, but I've heard that there is a company that makes a stand-alone computer to control the transmission only so I guess now you can throw it behind alot more motors now.
Matt
Old Jul 30, 2008 | 07:29 AM
alxsnmr's Avatar
alxsnmr
The C-6 was originally a big car transmission with high gearing to match. The E4OD is electronically controlled with better gearing for truck useage, i.e. lower first gear than a C-6, and an overdrive gear that the C-6 doesnt have. It depends on the year of E4OD that you are looking at, earlier E4ODs that have never been touched from the factory may need updates to equal the later model E4ODs. Previous owner usage of that tranny is another factor that is a heavy unknown, sometimes the tranny was left pulling or doing heavy work with the overdrive engaged. Doing so often burned the clutches and clutch plates up burning the rest of the tranny up from the debris. But all the autos are sensitive to debris in the tranny.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
