missing when you shift
Old Jul 29, 2008 | 09:17 PM
jacob_9249's Avatar
jacob_9249
i have a 84 ranger 2.0.and when you get on it just a little it misses when you shift.it does it only when you shift.1st to 2nd and to 3rd and 4th.i have changed the plugs,the wires.put it in time and i am lost.it will miss a little while then it will straighten out.until you do it again.any suggestions?i almost forgot i have rebuilt the carb to.
Old Jul 30, 2008 | 11:44 AM
pawpaw's Avatar
pawpaw
Well I see you've had 20 reads with no replies, so I'll try & get the ball rolling.
My first suspect, if it was missing during acceleration, was plugs too, but I see you've already changed them & the plug wires apparently without good effect.
Did you check/set the new plugs gap to min spec, before installing & did you properly torque the plugs????
What kind of condition is the distributor cap contacts & rotor in???? If they are worn, such that their gap is excessive, it'll put a weaker spark to the plugs, that could blow out under hard acceleration.
Other thoughts.
Did this problem begin AFTER you did the carb rebuild????
If so, maybe suspect a low float bowl fuel level, or maybe a weak shot from the accelerator pump. If all thats ok, check fuel pressure.
A bunch of thoughts for pondering. Let us know what you find.
Old Jul 30, 2008 | 04:36 PM
jacob_9249's Avatar
jacob_9249
missing
i gapped the plugs and torqued them right so i dont think its that.but i havent done the cap and rotor,the fuel pump just went out,so i am going to replace it,and see if i still have this problem.if it does it again,then i will do the cap and rotor.thats all i can think of i have done everything else.thank you!!!!!
cghstrojan08
1997 - 2003 F150
Dec 17, 2012 10:19 PM
dorton
17
Mar 31, 2012 11:23 AM
janvan
2004 - 2008 F150
Mar 6, 2009 07:34 AM
Fords&Farmalls
Dec 29, 2007 02:05 PM
mneal
1997 - 2003 F150
27
Sep 28, 2006 07:03 PM
