Torque specs for brake calipers
Old Jul 29, 2008 | 03:26 PM
pminne's Avatar
pminne
Rocky Mountain High
Does anyone know the torque specs for the front and rear brake caliper bolts for a 2002 F-250 7.3L 4WD? How necessary is it to get these numbers exact or simple "close enough" by feel? I am trying to avoid buying a $90 wrench if I can. Thanks!
Old Jul 29, 2008 | 03:34 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Pull on it as hard as you can with a 1/2" ratchet. I think the specs are somewhere in the range of 137-162lb ft.
Old Jul 29, 2008 | 04:06 PM
Ponyboychris's Avatar
Ponyboychris
With my 150 ft/lb torque wrench, I maxed it out. Then borrowed a mechanics at work and it was not far off the 162 ft/lb spec - like 159 or so. Like Kris said, you'll get close.
Old Jul 29, 2008 | 05:02 PM
HKusp's Avatar
HKusp
Real tight works good for me so far.
Old Jul 29, 2008 | 05:14 PM
PaysonPSD's Avatar
PaysonPSD
You didn't ask but the caliper slid pin bolts are 42 ft/lb.
Old Jul 29, 2008 | 05:39 PM
Ponyboychris
Oh, good catch...
Old Jul 29, 2008 | 05:44 PM
ron's power stroke's Avatar
ron's power stroke
like Jason...good and tight here too...only thing i TQ is the wheels... i cant say i ever used a TQ on any brake Jod i did..
Old Jul 29, 2008 | 06:12 PM
pminne's Avatar
pminne
Rocky Mountain High
Sounds like the consensus is to go with "real tight" and not use a torque wrench, a little less on the slide pins. Thanks guys, you saved me $90 (or more).
Old Jul 29, 2008 | 06:17 PM
Cracker 73's Avatar
Cracker 73
caliper mounting bolts frt 42 rear 27 ft pounds and the big bolt on cal mt bracket on ft are 166 and rear 128 these are all Ft-lbs I never use these now just go by feel but this is spec for our trucks 99 to 04 might help
Old Jul 29, 2008 | 07:32 PM
swaybar's Avatar
swaybar
i've done a hundred brake jobs over the years and have never used a t-wrench. just as tight as you can get them by hand.
Old Jul 29, 2008 | 08:41 PM
Ponyboychris
Or like the old joke in High School auto shop... "tighten until it goes easy then back off a half turn."
Old Jul 29, 2008 | 09:37 PM
camodown's Avatar
camodown
^haha yield out the bolts... that can't be good
I'd spring for a torque wrench. I got mine for $80 I think and it is precise to 150 ft lbs... pay for a better one... I blew the case out of mine trying to do u joint work... that was a pos wrench i guess...
Old Jul 29, 2008 | 10:07 PM
PowerstrokeJunkie
pminne, you should consider using $20 of that $90 you saved and become a supporter. See how much FTE is paying off saving you money? Show us
stbernard
Sep 15, 2015 11:00 AM
F-WhiteThunder
Dec 7, 2013 09:56 PM
mmenzies
May 21, 2013 11:58 AM
Diesel Submariner
Oct 19, 2012 03:41 AM
Riles34
1983 - 2012 Ranger & B-Series
Feb 8, 2009 03:59 PM
