TORQUE SPECS
Just done a full brake fluid flush and change.
Also pulled the Calipers and cleaned out the Slide Pins and Re-lubed them all. I also replaced the brake pads,
I had the Torque Specs for the Main Caliper bolts at 166Lb/Ft and the slide Pin Bolts at 42lb/Ft.
That seems to me, to be the Specs for the Front Discs only (I think
).I say that because the Rear Calipers are much smaller than the front set and therefore have smaller bolts.
Being smaller, I presume they would not be torqued the same as the larger bolts on the front
??Anyone know the proper torque specs for the 'REAR' Caliper holding bolts and the 'SLIDE PIN' bolts??
Cheers,
Reg.
https://www.ford-trucks.com/forums/8...uld-share.html
Thank you for the info
Also found this; just what I was looking for
Cheers,
Reg
These are torque values for a 2000 Ford truck. Most will be applicable to model years 1999-2003.<O
</O
<TABLE style="WIDTH: 100%; mso-cellspacing: 0cm" class=MsoNormalTable border=1 cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 0.75pt; PADDING-RIGHT: 0.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0.75pt">Description<O
</O
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 0.75pt; PADDING-RIGHT: 0.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0.75pt">Torque Specification<O
</O
</TD></TR><TR style="mso-yfti-irow: 1"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 0.75pt; PADDING-RIGHT: 0.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0.75pt">Brakes, disc, front brake caliper pin bolts (2)<O
</O
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 0.75pt; PADDING-RIGHT: 0.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0.75pt">42 lb/ft<O
</O
</TD></TR><TR style="mso-yfti-irow: 2"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 0.75pt; PADDING-RIGHT: 0.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0.75pt">Brakes, disc, rear brake caliper pin bolts (2)<O
</O
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 0.75pt; PADDING-RIGHT: 0.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0.75pt">27 lb/ft<O
</O
</TD></TR><TR style="mso-yfti-irow: 3"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 0.75pt; PADDING-RIGHT: 0.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0.75pt">Brakes, front disc brake caliper anchor plate bolts (2)<O
</O
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 0.75pt; PADDING-RIGHT: 0.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0.75pt">225 Nm (166 lb/ft)<O
</O
</TD></TR><TR style="mso-yfti-irow: 4; mso-yfti-lastrow: yes"><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 0.75pt; PADDING-RIGHT: 0.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0.75pt">Brakes, rear disc brake caliper anchor plate bolts (2)<O
</O
</TD><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0.75pt; BACKGROUND-COLOR: transparent; PADDING-LEFT: 0.75pt; PADDING-RIGHT: 0.75pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0; PADDING-TOP: 0.75pt">173 Nm (128 lb/ft)<O
</O
</TD></TR></TBODY></TABLE>
