Spring Help Please!!
Old Aug 4, 2008 | 02:50 PM
jpr38057's Avatar
jpr38057
I am guessing but I think all your other stuff should work but like I said I'm guessing. You will need to use new u-bolts though. I do know that.
Old Aug 4, 2008 | 02:53 PM
VR6Nutt's Avatar
VR6Nutt
I have new U bolts in the "package" I got...will have to check to be sure...so then whats the point of blocks?
also, different topic - noticed the MGB in your sig. Nice! I used to have a 64 Austin Healey 3000 MK3 Phase I BJ8. Miss that car!
Old Aug 4, 2008 | 04:23 PM
jpr38057's Avatar
jpr38057
What kind of package? Did this stuff come with the springs? If the u-bolts are used,get new ones. U-bolts aren't supposed to be used again. The blocks you are talking about are probably just the spacers between spring and pad.
I had a 76 midget but just could not get in and out of the darn thing so I got something bigger. Bought the MGB and my wifes Ex within a week of each other. Found them both on ebay and both in Florida 30 miles from each other. Wanted an MGB ever since I was a kid.
Old Aug 4, 2008 | 06:53 PM
SFeintuch's Avatar
SFeintuch
The loose single springs you have are not fronts, They go on top of the rear packs with a spacer inbetween. The side marked front goes toward the front of the truck. Hope that helps a little. If you do a little searching you can find some pictures of the complete assembly.
Old Aug 4, 2008 | 10:28 PM
Stewart_H's Avatar
Stewart_H
What loose springs?I mighta missed something (wouldn't be the first time!) but I don't see any loose springs in the posted pictures.
To keep the rear end from being lower than the front end, after doing the spring swap, because upgrading the fronts raises the Excursion a bit.
Stewart
Old Aug 5, 2008 | 06:39 AM
SFeintuch's Avatar
SFeintuch
To Stewart_H.....Read post #11
Old Aug 5, 2008 | 11:28 AM
VR6Nutt's Avatar
VR6Nutt
The loose leafs are in the first picture, leaning against the wall. They're underneath the rear leaf pack. Did some searching and lotsa reading. Seen Stewarts been thru this already. Still fuzzy on where that loose leaf sits...doesnt really match up with any of the pics I found.
Old Aug 5, 2008 | 11:57 AM
Stewart_H's Avatar
Stewart_H
Wait, wait, wait!! I'm a picture book kind of guy....you mean I gotta read too??????
Oh man!
Thanks for pointing out the obvious for me.
Blind Stew
t.r.c
1978 - 1996 Big Bronco
24
Aug 14, 2016 11:03 PM
1FastGambler
Offroad & 4x4
May 1, 2016 10:39 AM
VR6Nutt
Sep 10, 2015 05:26 PM
Big-Sarge
6.7L Power Stroke Diesel
40
Feb 5, 2012 10:55 AM
tiger_698
33
Apr 24, 2010 07:22 AM
