Need help diagnosing injection system
Old Jul 29, 2008 | 03:18 AM
01FordCrew's Avatar
01FordCrew
Question Need help diagnosing injection system
I purchased my 01 Ford with 450,000 km's. I don't know if any injection work has been done to it. Last winter I think I had water in my fuel because the fuel system seemed to freeze up and left me stranded or limping home wondering if I was going to make it. After thawing in a heated garage, adding deicing fuel conditioner, and changing the fuel filter it ran better. I had to do this a number of times before the problem completely subsided.
Lately a number of people have commented how choppy the truck sounds(I am running a straight pipe and I don't know if a straight pipe will normaly make it sound extremely choppy or not). The thing that piequed my curiosity is that both my mother and neighbor made comment that the truck at different times sounds rougher(awful) than other times. My mom said that "as I drove past it sounded kind of boggy, not like you(meaning me) want it to sound". I can't say I have particularly noticed but they are getting the sound full volume and I have a cab to insulate me from some of the sound. I have previously had the high pressure oil pressure too high/low code. I recently added fuel conditioner and I thought I noticed it smooth out a bit but after that tank of fuel it has slowly returned to how it ran before.
Are these symptoms indicitive of possible injection system concern? How can I check the health of the fuel injection system?
Old Jul 29, 2008 | 03:42 AM
ron's power stroke's Avatar
ron's power stroke
does it smoke at all?? any loss of power?? do you mean chopy as sound?? or it skips and spudders.. if she froze up a couple of times..id say you got some bad fuel some place...if it was mine i would drop the tank and give her a good cleaning then do the in tank mod.. ITP 7.3L Fuel Tank / Pre-Pump Kit
Old Jul 29, 2008 | 06:22 AM
Kwikkordead's Avatar
Kwikkordead
In addition to what Ron just said, remove the valve covers and make sure that all the connections are fully secured.
Retorque the injectors to 120 inch pounds.
Retorque the rocker arm pedastals to 20 foot pounds.
Sorry I don't know how to convert to Newton meters, but those are the values.
If that doesn't do it, then you may be looking at some injector replacements.
That is a long time for those to go without any sort of servicing. There is a poppit valve inside the injector that wears out and then they won't fire, or will be very lazy about doing thier job.
Old Jul 29, 2008 | 06:28 AM
F350-6's Avatar
F350-6
I can't say enough good things about this. I re-torqued mine about 1,000 miles ago. My wife made the comment it sounded like I've got a new engine under the hood. My torque wrenches have ft lbs & NM listed on them. Maybe yours will too.
Old Jul 29, 2008 | 06:31 AM
Kwikkordead
Yeah, what a difference it makes.
Old Jul 29, 2008 | 09:05 AM
Mike F250's Avatar
Mike F250
ft-lb to n-m conversion calculator
Torque Wrenches
Old Jul 29, 2008 | 10:53 AM
PaysonPSD's Avatar
PaysonPSD
Torque Wrenches
Nice conversion calculator Mike.
Old Jul 29, 2008 | 11:58 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Sounds to me like you need to get your fuel from another station just for starters.
Old Jul 29, 2008 | 02:38 PM
Mike F250's Avatar
Mike F250
thanks Robin. Right after I found this link it reminded me to head to Sears to get a few replacement ratchets and I have always wanted to get an inch pound wrench. Got back to my desk and found the calculator didn't work. Here's a new one that does...
Maryland Metrics: Online Metric torque conversion Calculator
Old Jul 29, 2008 | 03:05 PM
PaysonPSD's Avatar
PaysonPSD
The other one worked for me but I'm saving this link as well. It's better and easier.
lmnr0026
Nov 25, 2008 11:01 AM
thedaddycat
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Apr 5, 2008 12:42 PM
bigolbob
30
Dec 19, 2006 12:53 PM
furrby
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Dec 13, 2003 10:19 PM
coorslight4u
Mar 21, 2002 09:53 AM
