Modular V10 (6.8l)
Plug Change - Injector Connector
Old Jul 28, 2008 | 10:47 PM
Mr. Obvious's Avatar
Mr. Obvious
I changed the plugs/boots last week in my 2000 V10 Ex with 92,000 miles on it.
I think the plugs were original since they were the old style. Anyway all were tight and worn 10 thou bigger gap than the new ones.
I put the new ones in at 30 ft=lbs and had no issues with torque.
I removed 2 injector electrical connectors to get more room and both times the plastic flexible piece that holds it on broke as I squeezed it. I had to put a wire around them when I reconnected them to make sure they wouldn't work themselves off.
Anyone have this problem or know if the connectors are easily replacable?
Old Jul 29, 2008 | 09:06 AM
ZBIGBIG19TH's Avatar
ZBIGBIG19TH
Had same problem with the first one I'd tryed to remove.Just slide it on the injector and
till now (6 months)no problems.Did you torqued 30 ft/lb dry or with anti-seize?
Old Jul 29, 2008 | 11:42 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
A few people have said the same thing - besides getting a new harness and either changing the entire thing or splicing on the connectors, there's no other obvious fix.
Plastic tie wraps work well I've heard
30ft/lbs? Sheesh... at least if you had any bad threads, you'd find out real fast...
Old Jul 29, 2008 | 03:17 PM
Mr. Obvious
I did not use any antiseize.
Thanks for the info.
Didn't look like it was replaceable other than cutting the wires and soldering on a new connector.
Metz12345
Jan 19, 2015 06:48 AM
slrassoc
1983 - 2012 Ranger & B-Series
Jun 6, 2012 04:21 PM
mrbudman13
Nov 23, 2008 09:37 AM
Brad4321
Sep 10, 2006 04:09 PM
