Modular V10 (6.8l)
AC help
Old Jun 13, 2008 | 10:51 PM
Fastbird's Avatar
Fastbird
AC help
Hi,
I do have 99 V10 and my ac is not working good.Cool fine for a while,then eventually quit cooling,and begun blowing warm air.After few minutes start blowing cold air again.
Local ford did refill last year.
Thanks Jaromir
Old Jun 14, 2008 | 04:51 AM
Monsta's Avatar
Monsta
Sit. Stay.
Have you checked the pressure THIS year?
Old Jun 14, 2008 | 02:35 PM
Fastbird's Avatar
Fastbird
No,how do i do it?
Old Jun 14, 2008 | 05:08 PM
Monsta's Avatar
Monsta
Sit. Stay.
There are a number recharge kits at automotive supply stores and Wally World. They have pressure gauges on them as well. You should get one and recharge or verify the charge. You *may* have a small leak.
Old Jun 16, 2008 | 06:19 PM
Heavy_Metal's Avatar
Heavy_Metal
Also, ford, in thier infinite wisdom didn't put a bypass valve inline of the heater core like most cars have. Causes the AC to work harder and actually blow warmer than it should. I bought a rv water heater manual bypass valve and hooked it up in line. Turn it off in the summer, on in the winter. AC blows 10 times colder in the heat.
You on the other hand may have a leak. Have a jiffy lube or somebody put some dye in it and look for green liquid. Replace leaking part. Reservice.
Old Jun 16, 2008 | 11:44 PM
Jax 99's Avatar
Jax 99
heavy_metal- where did you buy the rv bypass valve?
thanx
Old Jun 17, 2008 | 06:53 AM
projectSHO89's Avatar
projectSHO89
Most likely, the OP's problem has nothing to do with either the charge level or the engine coolant lines.
Sounds like another excessive clutch air gap or a broken blend door which are both well covered in the HVAC forum.
Steve
Old Jun 17, 2008 | 01:18 PM
Monsta's Avatar
Monsta
Sit. Stay.
The air gap I can see, the blend door; probably not. It goes cold then warm, cold then warm etc. etc. The blend door typically sticks and doesn't move when it is broken
First and cheapest thing to check is the refrigerant. If that checks out there he should progress from there.
Old Jun 17, 2008 | 05:24 PM
Heavy_Metal
Ace Hardware, $7.99. I'll get the part # for ya next time I see my truck....
Old Jul 29, 2008 | 07:15 PM
Jax 99's Avatar
Jax 99
Heavy_Metal,
if i go into ace hardware and ask them for a RV bypasss valve will they know what im talking about?
or did you happen to find the part #.
thanx
Old Jul 29, 2008 | 07:35 PM
jpr38057's Avatar
jpr38057
Look on your heater hose to see what size it is. Hopefully it's on there. You can go into Advance, AutoZone or Napa and tell them you want a water shut-off valve for what ever size hose it is.
jdm5630
May 26, 2011 02:55 PM
gdore28
1997 - 2003 F150
Aug 25, 2010 05:22 PM
mholden1966
Jun 13, 2010 03:07 PM
