Spewing oil
Old Jul 28, 2008 | 06:44 PM
rocco722003's Avatar
rocco722003
Spewing oil
I have a 1999 f250 superduty diesel that ran out of fuel, now it's blowing oil everywhere. Is there a connection? This comes after taking off the fuel tank and cleaning it due to bad gas. After cleaned a few gallons were added and I ran back into the house to get something and before I could get back out it was out of fuel. I went to the store and got a few more gallons put it in, truck started right up. But now I have no power and I'm spewing oil.
Old Jul 28, 2008 | 07:00 PM
clux's Avatar
clux
Can you tell where you are spewing oil from?
Old Jul 28, 2008 | 09:09 PM
rocco722003
99 f-250 diesel
It looks like it is comming from the seep hole in front of the flywheel, as well as it is leaking all around the oil pan but it seems to get worse as the truck runs and the longer the truck runs the worse the power loss. another question i have could the fuel pump be bad? I was always under the impression that either the pump works on does not work?
Old Jul 28, 2008 | 09:26 PM
clux's Avatar
clux
Look on top of the motor. A lot of oil leaks that look like they are coming from the seep hole actually start in the engine valley on top and run down the back of the engine.
Old Jul 28, 2008 | 09:31 PM
rocco722003
When i looked at the top of the engine i noticed a puddle behind the fuel filter and thought it was residule fuel from draining the filter to blrrd the system but it did look like oil
Old Jul 28, 2008 | 09:35 PM
clux's Avatar
clux
There's a good chance you are leaking oil from the high pressure oil system, either the pump o-rings or the hoses. This might also be causing you out of fuel symptoms. You need to find out for sure if it is oil on top and if it is, where it is exactly coming from.
There's a forum dedicated to the 7.3 diesel super duty pickups on down the main FTE page. If you post you problem there you'll get a lot more responses.
Old Jul 29, 2008 | 11:25 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved to the 7.3L forum
Old Jul 29, 2008 | 12:21 PM
rebelchevy02's Avatar
rebelchevy02
With the engine running, look on top to see were the source of the oil is dripping. Its also not a bad idea to clean up the top first, to make finding the oil leak easier. Be sure to have a flashlight, its kinda dark up there, specially with a person covering it! Good luck
Old Jul 29, 2008 | 02:07 PM
Ponyboychris's Avatar
Ponyboychris
Here's a recent thread with similar issues:
https://www.ford-trucks.com/forums/7...e-oil-pan.html
Probably the HPOP o-rings need replacing. Read this as well: HPOP O ring change
