Help, oil pouring from hole behind the oil pan!!!
Very rare to have a rear main go out on these engines, Do what Chris said and look in the valley of the engine to see if you see oil pooled in it. Look under the turbo, might be an o-ring on the pedestal leaking. Look in the front of the engine, might be a line off the HPOP leaking. Look good with a flashlight.
It drains out the back of the block under the turbo, down the back and leaks out of the inspection hole of the tranny. Sounds like your deal? I say this because that what myine did and my first assumption was a rear main seal. Especially, if your truck sits nose up in the driveway like mine does. How much is leaking? dime size, Valdez oil slick???
Here's a link to get you familiar with the HPOP o-rings.
HPOP O ring change
Now, there is another plug in the bottom of the HPOP that is harder to fix but is fixable. I'm looking for that link now.
On edit: you said pouring out - so sizable leak.
HPOP O ring change
Here's the fore-mentioned link about the plug:
https://www.ford-trucks.com/forums/5...look-here.html
HPOP O ring change
HPOP O ring change
Thanks for your help!!!!
I guess it depends on how fast you need them. Some of the sponsers have the o-rings or you can get them from the dealer. They need to be of a certain material.
Did you find the leak?
No the truck is still at the house, I am at work. Gona have to look at it when I get home. Just thought it would be faster to get them at the LPS.
Yet another link:
DFUSER Diesel Performance Products Exhaust High Performance Part Diesel Intake Diesel Power Chips
Both the turbo and the HPOP o-ring kits are listed here.
