Sponsored by: Kumho
2003 excursion swaying propblem, help!!
Old Jul 28, 2008 | 04:26 PM
rcw1614's Avatar
rcw1614
i just got a 03 excursion and love it , it just has alot of swaying and seems to be very hard to control im all over the place. alinement, brakes, are good no pulling ect. please help thx!!
Old Jul 28, 2008 | 06:13 PM
ReAX's Avatar
ReAX
Sway bars reduce body roll, and most body roll happens during cornering. However if it's windy you have a large enough profile to be knocked around and a bigger sway bar or poly bushings could help.
What shocks do you currently have and how many miles are on them?
Old Jul 30, 2008 | 07:48 AM
rcw1614's Avatar
rcw1614
well i just got the truck so i will check the shocks it has 80,000 on it and what is a good swaybar for that truck or does it matter?. thx for the help
Old Jul 30, 2008 | 08:19 AM
stuart1's Avatar
stuart1
Have a look at the track bar.
Here is a quick test.
Start the engine.
Apply the brakes.
Turn the steering wheel from 3 to 9 oclock and watch for movement on the front of the vehicle.
A bad track bar will show up as movement.
Old Jul 30, 2008 | 11:37 AM
ReAX's Avatar
ReAX
Addco and Hellwig are the only two companies I can think of that should have a set of bars for you.
Old Aug 3, 2008 | 01:35 AM
Rackpatrol's Avatar
Rackpatrol
I have had the same problem. I have replaced, all ball joints,drag link, tie rods they whole 9 yards. New shocks and tires, Allignment, and sway bar. But when I checked the camber I found that both sides had a problem. So a friend at work told me to check my clearance from my bump stop on my front springs. I have a 1/2" on one side and 5/8" on the other. Also where the bump stop hits the springs it polished clean from constant bottoming out. And from what I have read BAD CAMBER = BAD WANDERING. I have the 7.3 DIESEL ENGINE. and the talk is that ford put to soft of springs under the EXCURSION diesel, for the softer ride. So some of our fellow FTE buddies have convinced me to put F250 diesel springs on it. Stewart_H has done a nice step by step post on how to change the front springs out, with some great pictures.
Old Aug 8, 2008 | 07:33 AM
rcw1614's Avatar
rcw1614
thanks so much i will check this out this weekend, the shocks seem fine and i checked the 3-9 wheel turn and thats good too and as for the sway bars i think that will help on the highway but my real problem sounds like the camber because at low speed high speed straight road i seem to dart or wander all of a sudden in a differnt direction. im like araid to take my eyes off the roads because i wont be where i should. so i will check the spring height next, then a garage for the camber check.
thank you so much for the help. bob
4x4x
Jul 17, 2013 10:02 PM
EX40
WTB - Parts & other
Jun 3, 2011 03:05 PM
01 EXCURSION MORRIS
Aug 13, 2009 06:18 AM
zavierbr
May 27, 2009 06:25 AM
JSPajak
Oct 22, 2007 10:22 PM
