Safe to run 40 PSI in my tires?
Hi guys and gals. I searched first but couldn't find anything. Maybe I didn't put in the correct phrase..?
I was wondering if it would be okay to run 40 psi in my Dayton Mud Terrains? 31x10.50x15, supposed to run 32 psi. Talked to a guy the other day with identical tires and size and he says he runs his at 40 psi with no problems.
The reason I'm wanting to raise my tire pressure is for gas mileage / less work for the motor. Is this a safe thing to do? I don't drive much faster than 60 mph on the highway. 85% of my driving is city driving, on rough roads. Right now I have my tires at 35 psi.
I know this question may seem paranoid but I don't want to hurt anything / anyone / or bust a tire.
Thanks in advance everyone!
Back in the day, you could get a Bronco with 31x10.50s on it from the factory...recommended tire pressure for them was 35 front/41 rear.
I have my 31s set at 40 PSI all around...I seem to have as good tire wear as can be expected.
Just curious, Bill...where did you come by the 32 PSI figure?
Pat
Pat
When you run your pressure to high it wears out the center faster than the rest of the the tire because that is what is getting more contact with the road. The bad thing about that is your tires will wear our faster because there is less tread on the ground so unless you like buying tires all the time don't run them too high. The opposite is true for too low of a pressure setting you will wear out the outside of the tire faster to the same effect.
Thanks guys! I appreciate all the info.
I checked my maximum tire pressure and it's 40 psi. I think I'll take out a few lbs this weekend just to be safe. The roads around here are in bad shape. Even though I don't drive like an idiot sometimes a pothole or large lump in the road will sneak up on me.
whiteaddiction
02-05-2009 03:38 PM
