F350/Dana60 alignment
Old Nov 19, 2010 | 09:26 PM
greywynd's Avatar
greywynd
So as you I mentioned recently, I got the F350 crew up and running. Took it for a spin the other day, and felt why the one front tire is badly worn unevenly, the alignment is terrible! I suspect the toe-in is out quite a ways, but the wheel was also about 90degrees from being centered too.
What I want to do is to adjust it at home to get it closer than it is, so I can swap the bad tire for a good one, then take it to get aligned without destroying another tire.
I know toe-in should be about 1/8" or so difference, and know where/how to adjust it. What I'd like to know is how to go about getting the steering wheel closer to centre again!
Old Nov 20, 2010 | 05:16 AM
tjc transport's Avatar
tjc transport
i ain't rite
i set the toe between 1/16 and 1/8.
to center the steering wheel, you will need to remove the link from the pitman arm and center the wheel.
then adjust the steering links to have the tires pointing straight. it is not that hard to do if you start out with the tires pointing straight.
Old Nov 21, 2010 | 10:35 AM
greywynd's Avatar
greywynd
The link from the pitman arm? Are you talking about pulling the arm off the steering box? I thought that had a master spline?
Old Nov 21, 2010 | 10:58 AM
rodneywar's Avatar
rodneywar
he meant the tie rod from the pitman arm
Old Nov 21, 2010 | 12:45 PM
greywynd's Avatar
greywynd
Ahhhh, okay, now I think I'm getting it. First adjust the toe in by adjusting the wheel to wheel linkage. In my case, I suspect it's off enough that when it is adjusted it will affect the steering wheel anyway....so it may even correct that. If not, pop off the tie rod end from the pitman arm, centre the wheel, then thread the tie rod end in or out to suit for centre.
Now... in the past to measure, I always spun the tire to mark a line with a tire crayon or chalk, then measured from line to line. Anyone got any different/easier suggestions?
Old Nov 21, 2010 | 03:46 PM
tjc transport
i ain't rite
if the wheel is off that far, i will disconnect the link from the pitman arm first. then center the steering wheel by going turn lock to turn lock, and dividing that in half to find wheel center.
then set the toe, and lastly set the tie rod to pitman arm.
and i set the toe by measuring from front to back, center of the wheels where the rim meets the tire.
Old Nov 21, 2010 | 10:28 PM
tecgod13's Avatar
tecgod13
I took a small brad nail and put it in a thick lug in each tire. Careful!! not INTO the tire, just in the tread part, so like no more than a 1/4 inch or so in. Then rotate so thats pointing straight forward on both tires. Hook tape measure on one side, read measurement from the other side. Rotate tires 180 degrees so nails are pointing straight back and repeat measurement.
It worked really well, was easy to get an accurate measurement.
BioBurner
Aug 2, 2017 01:51 PM
bulldogcountry1
Mar 23, 2017 12:26 AM
MontanaMan
Oct 26, 2011 06:26 PM
jrfiero
Oct 15, 2010 03:48 PM
hladun
Dec 19, 2004 06:53 AM
