Aerostar Ford Aerostar
Off topic. Taurus quation
Old Jul 28, 2008 | 03:42 AM
Pablo-UA's Avatar
Pablo-UA
when I drive at low speeds in curves I feel like PS pressure fluctustes with 2-3 sec. dalay. I do not know what can cause it. I'm not sure has my car VAPS ore not. There is idea to disable it but what steering pressure I'll get?
P/S. It is '94 XLT, 3.8
Old Jul 28, 2008 | 08:27 AM
aerocolorado's Avatar
aerocolorado
VAPS was an option on the 3.8L equipped engines. If so equipped, there should be an electrical connector at the top of the rack & pinion gear box. I'm not 100% positive, but I believe the VAPS uses a variable solenoid very similar to the IAC valve operation. You should be able to disable it without any changes to the power steering pressures.
Old Jul 28, 2008 | 08:33 AM
Pablo-UA's Avatar
Pablo-UA
will steering be light ore firm when VAPS is disabled?
Old Jul 28, 2008 | 05:39 PM
aerocolorado
As I understand the VAPS system, it gave maximuml boost for low speed operations, mainly for parking and slow speed turning situations and slighly less boost as speeds exceeded a pre-set value. Apparently it depends on which speed you disable the VAPS system as it stays in whatever level of boost it was in when disconnected. Here is a good article about modifying the VAPS system: Adjusting the VAPS (Variable Assist Power Steering) :: SHOtimes FAQ :: Frequently Asked Questions (FAQ) about the Ford Taurus SHO from the SHOTIMES mailing list.
batman3n1
Jun 5, 2011 07:02 PM
HerculesEngine
Jan 23, 2010 06:38 PM
derherr65
Aug 16, 2006 09:45 PM
d_stange
Mar 15, 2006 12:56 PM
xanthias
Feb 20, 2003 05:34 AM
