Brake Qwestions
Thanks Guys
Your question was ...what to look for...well you do NOT want to see any brake fluid oozing out of the Wheel Cylinder on to the drum or well, really just anywhere.....
You want to see that all hardware is sound..no excessive wear spots...like on the bottom where the adjustment sprocket is turned.. Now, bear in mind...I have had 'sound looking' brake hardware break on me as I was reassembling.....and I have had the top spring snap on me after a long time had passed.. But in those days I was a hard driving fool...straight up idiot..so I went through some brakes...
You want to see that the friction surfaces have plenty of 'meat' on them.. There are two types shoes...Bonded and Riveted...there is a minimum thickness for each..but basically if it's looking like it's getting less that 1/8 thick put new ones on..I think you're talking like $60 for 4 shoes in the rear and about the same for the front...
In the front, you want to look for ...Grease on the Brake Assembly...you don't want any ...in the rear...look for axel oil....you don't want any ...if you have ...you have a failed seal...
On the drums...look for excessive wear...I just did quickie brake job on an F250 and on the passenge side you could see where the shoes had worn their own groove into to drum...NOT the rivets the entire width of the shoe had worn into the drum....my guess is that someone had let the bonded type of shoe go metal to metal at some point...The existing shoes had plenty of meat....but the drum was just shot... ($135 a drum)
Another type of wear you DON'T want to see is groves in your drum this is caused when riveted shoes have gone metal to metal....
If you see that type of wear on a drum...go get new ones or at least plan on getting them when you do the brake job...
If you see oozing brake fluid from the wheel cylinders ...just go ahead get new ones... It's best IMO...I just never had ANY luck trying to rebuild wheel cylinders...it just didn't work for me ....
TH1567
I'm sure someone will fill in with all kind of technical information I'm not furnishing...
My mother had a rear hose blow in her '65 Mustang and it left her with NO BRAKES, fortunately she was returning from the neighbors and was able to slowly coast into the driveway. The one major drawback to the single reservoir master cylinder!!
I'm no mechanic...just guy that had one or two rolling wrecks to keep ready for that Monday to Friday work week..
Thanks for the compliment...but as I said..there's a lot of technical details I know nothing about....
TH1567
There's a wide, wide world out there...get out in IT. Drink experience down to the dregs and live...
good luck.
Course that's a 1966 F250....2 inch shoes...a set of them were $60....the wheel cylinders ...$47~ each...plus chemicals and a couple of lug nuts...
TH1567
.....Goin up the country, gotta get away...
Get a brake spoon...It's always wise to back down the brakes away from the drum using the brake adjustment 'pin wheel'.
Rears: If 1/2 ton, remove wheel, remove drum.
For stuck drum, make sure you adjusted brake shoes AWAY from drum...keep going ...keep going.....try to remove drum...No Go? get a hammer....not a big one...may a 2 pound mini sledge..and if you can...as you turn the drum and tap it from the back side..
You can also just tap around the drum itself.. NOT TOO HARD...just good sound taps...may be just slightly rusted to its seat...
Still not budging....get a piece of wood and hit the back edge of the drum do this all around the drum NOT in one place.. This will prevent it from binding
NOTE: Hitting/pounding on metal heats it up...that's a good thing in moderation when removing difficult parts ...like a drum
On 3/4 Ton...remove wheel, remove 3 Machine Srews, Loosen Brake Shoes away from drum,...remove drum....
NOTE: The cover/flange/hub on the 3/4 tons can be an area where the 3/4 ton drums can prove difficult to remove....I had to gently grind away some of that flange to get the drum off...just a taste here and there...
Use guidelines for hammer usage as on 1/2 ton if drum proves difficult....
TH1567
.....Yep, it's Sunday..
