good day i have a set of white gauges i got from ebay heres the ebay #s
seller:white gauges
73/79 set # 360066341111
paint for speedo # 360064946766
if you are going to order from this company i would also order the paint as you need to [1] paint the speedo white [2] use a fine tip black marker and paint the numbers this is required as our trucks have raised numbers [very easy to do with a steady hand i you realy want the cool factoer and brighter gauges change out the regular bulbs for leds i have red in mine and i love it not sure how to post pics in here so my gallery is "class of 78" 1978 f250 2wd hope this helps regurds joe
preciate teh input, what rear disc setup is that you have on the rear of your truck miottimouse? looks like a pretty clean setup, how do you like em, did you change the prop valve or master cylinder?
ebays gotta be the greatest thing ever!! find some good stuff on there once in a while the person i bought the brakes from is roger livingston ph 902 292 4430
cant remember where he"s located but he supplys the bracket,roters are from a 78 chev 4x4 calibers are from a 76 cady eldoreldo no prop valve or master change stops fast and straight a perfect setup and the real nice thing i like, they work when you need them to i dont have to jack up the rear end any more and set the star wheel manualy as the 5 trucks i had in my life time all had the same problem with rear brakes that would not self ajust even the e brake cables worked with a home made bracket cost about $600.00 2 years ago but worth it hope thi helps regurds joe
duece i got the red led lights #94 if i remember right from superbrightleds.com they have lots of colors but the white gauge kit realy sets them off i have red in the pickup and yellow in my 79 granada my over head console also has red looks cool and very bright at night regurds joe
