SENDING UNITS OR GAUGES???
Old Jul 3, 2000 | 06:03 PM
bearclaw's Avatar
bearclaw
Old Jul 6, 2000 | 12:25 PM
torp's Avatar
torp
I have dual tanks on an 84 extended cab. My fuel gauge acts weird on both tanks. When I fill up, the gauges work fine. After I get down to 3/4 tank, the needle crashes all the way to the bottom. Seems to me that since this problem is on both tanks its not a sending unit. Is there any way to test the gauge itself? Thanks in advance.
Torp
84-XCAB-2X4-302
Old Jul 7, 2000 | 01:19 AM
Superdave's Avatar
Superdave
I had the same problem with the rear tank on my 82 F-250. It was the sending unit in my case. It consists of a tightly woven spring looking deal which is called a reostat. I can't remember which section was which, but when the float would reach the part on the reostat that was all frayed the fuel gauge would drop to nothing. Replaced the sending unit and its never had a bad day since .
Superdave
94 Ford Aerostar XL 3.0L
82 Ford F250 4x4 XLT,400 CID,C-6 A/T,8700lb GVWR. Black & Silver
Old Jul 8, 2000 | 02:47 PM
drdowning's Avatar
drdowning
check also the switching valve that changes from tank to tank... there also may lie the problem. I have the same sort of thing except both tanks read high.
good luck
Dr d
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
