A Sears driver training manual says that in cold weather before attempting to start your car you should turn on the parking lights for 5 or 10 seconds to prime the electrical system. This supposedly will improve cold winter starts. Would someone who really knows electrical stuff comment. This sounds plausable, yet fishy. Thanks.
INLINE SIX POWER! '95 F150 XL
300 Cubic Inches of Low RPM Truck Torque! And twin-I-beams too!
"Drive a stick young man! There'll be time for automatics when you're old and unable."
I've heard that before. I think what it does is gets the electrons moving in the battery and acrually heats up the battery a bit. Weather it really does any good? I don't think that you would ever notice the difference.
If you have a fully charged battery, and put a test load on it; you will see a drop in voltage for a few seconds or minutes depending on battery size and load. Then the voltage will start to rise for a period of time. It will reach a peak and then begin a slow decline as it discharges.
There might be something in turning on the parking lights, but I would like to see some hard proof. I would feel better with the bigest battery that I could fit under the hood.
I have absolutely no proof of that theory but.... if you turned on the lights the battery would heat up from the current draw and since a warm battery "works better" than a cold one it is possible but.....
