Clunk! Clack! What Broke?
Old Jul 25, 2008 | 10:58 PM
B1GKAHUNA's Avatar
B1GKAHUNA
yesterday i put truck in 4wd and it drove fine straight. when i turned i heard clunk and it felt like a flat tire and wheel shake to the point of stopping truck or breakage of something. so i put it back in 2wd and drove fine even in turn. then today, 2wd turning in to park, full turn , i heard a clack! i looked under truck frontend, dont see anything broke! what's going on??????????please help!!!!
Old Jul 25, 2008 | 11:16 PM
Lead Head's Avatar
Lead Head
CV Joints, or hubs.
Why were you driving on the road in 4wd?
Old Jul 25, 2008 | 11:58 PM
B1GKAHUNA's Avatar
B1GKAHUNA
because i rarely use 4wd and i was told to put it in 4wd once a month to keep lubricated
Old Jul 26, 2008 | 07:40 AM
BowTieHatr's Avatar
BowTieHatr
your hub may have stuck momentarily. the auto hubs are a great design untill they start sticking, then your axles lock without warning and can stay locked in whether you want them to or not.
Old Jul 26, 2008 | 09:09 AM
Lead Head's Avatar
Lead Head
I don't know about that, my dads 2003 Envoy only uses 4x4 about once a year, and its just fine, and so has every other 4x4 vehicle we've owned, including this ranger. Driving on straight dry road with 4x4 on is very bad for the drive train. When your turning, the front drive shaft and wheels want to turn at a different speed then the rear drive shaft and wheels, causing the system to bind up.
Old Jul 26, 2008 | 09:22 AM
dcaddi2's Avatar
dcaddi2
Climb under your truck at the front axle, and with hand move your joints , make sure they dont stick. If any ( usually one of them ) does, then play with it to get it loose...
Old Jul 26, 2008 | 11:39 AM
mxer0022's Avatar
mxer0022
going along with what Lead Head said it isn't good on the 4 wheel drive to have it active and running it on asphalt. especially if you are doing any turning. it will tear your joints, differential and transfer case up quick, fast and in a hurry!
Old Jul 26, 2008 | 02:42 PM
datsun_1600's Avatar
datsun_1600
Yeah I agree with mxer0022 and Lead Head, runn'n it in 4x4 on asphalt with no center diff (ie GTR, WRX etc) is going to destroy your transfer case etc faster than you can count to ten..
JT
Old Jul 26, 2008 | 10:17 PM
B1GKAHUNA's Avatar
B1GKAHUNA
well im glad i stopped and put it in back in 2wd. so no need to to put in 4wd to lubricate?
Old Jul 26, 2008 | 10:21 PM
Lead Head's Avatar
Lead Head
The differential and the chain/gears in the transfer case are not turning while in 2wd, so there is nothing that needs lubricating. The hubs are packed and sealed with grease, so they are lubricated all the time
Old Jul 26, 2008 | 10:23 PM
mxer0022's Avatar
mxer0022
it probably wouldn't be bad to do it occasionally but just make sure that you find some dirt to do it in. even if it's just a dirt road for a couple of miles.
Old Jul 26, 2008 | 10:55 PM
B1GKAHUNA's Avatar
B1GKAHUNA
why would it drive different on dirt than pave?
Old Jul 26, 2008 | 11:21 PM
Lead Head's Avatar
Lead Head
I explained it earlier, the front tires track differently then the back, for instance, when taking a turn, the front wheels will travel a much farther distance then the back tires. The different locks the driveshafts together, so what happens is the transmission is trying to drive the transfer case and rear wheels at one speed, but when your turning, the wheels and front differential are trying to make the transfercase go faster, but its being limited by the engine and the rear wheels. Thats why sometimes you might notice the front wheels bouncing or squealing while in 4wd on the road.
It gets the whole drive train in a huge bind, and puts tremendous stress on the differentials, transfer case, CV joints, and the hubs.
When your on dirt or another slick surface, the wheels can slip a bit, so nothing gets bound up.
Now about AWD, there are two types of AWD, one is where the transfer case is always in a "ready" state to engage 4wd, and when the computer senses slipping, it slams it into 4x4 instantly, then takes it out when traction is regained.
The other kind has a differential between the front and rear drive shafts, allowing the front and rear wheels to travel at different speeds.
Old Jul 27, 2008 | 12:43 AM
mxer0022's Avatar
mxer0022
great write up lead head! B1GKAHUNA take our words for it buddy! this isn't something we're just pulling out of our butt.
Old Jul 27, 2008 | 03:16 PM
KR DRIVER's Avatar
KR DRIVER
You said it also did it in two wheel drive right?
Might noy hert to check rear diff also .
I had somthing simular to that effect on a nother vehical and it turned out
spider gears were just about gone
