vin id code for the rearend
Old Jul 25, 2008 | 07:40 PM
du$ty's Avatar
du$ty
these numbers are off the vin code off a parts truck i just picked up..i know its a custom cab and i think it is a 63 and i think it had a six and i know its from califorina..but ..can any of you help me identify the gear ratio this truck came with.
f10gr432755
122af10081ba12
Old Jul 26, 2008 | 05:30 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
f10gr432755 / 122 a f100 81b a 12
F10 = F100 2WD
G = Incorrect engine code (G: 401 gasser only used in BIG trucks). If the code is (prolly) a C = 292 2V.
R = San Jose CA Ford Assembly Plant
432755 = 1963, assembled in July.
122" Wheelbase
A = Raven Black
F100 = F100 2WD / 5,000 lbs. GVWR
81B = Custom Cab
A = Ford Type 3.03 / 3 Speed Manual all Syncromesh Transmission.
AXLE Code 12 = Ford 9" / 3.89-1 / non Limited Slip / 3300 lb. Rear Axle Capacity
Decode source: 1957/63 Ford Truck Parts Catalog
Old Jul 27, 2008 | 12:10 AM
blloyd's Avatar
blloyd
ND, How did you figure out the truck was assembled in July by the numbers ??
Old Jul 27, 2008 | 12:20 AM
Dan Edick's Avatar
Dan Edick
the assembly date is somewhere in the VIN.easy to decode with a parts manual
Old Jul 27, 2008 | 12:54 AM
NumberDummy
The 1957/63 Ford Truck Parts Catalog breaks down the serial numbers to the month the vehicle was assembled.
The serial number is the last 6 digits of the VIN.
July 1963: From 430,000 thru 439,999.
Your 1963 F100: 432,755
EZ to do with a parts manual?
That month breakdown only applies to 1961/63. After 1963, ALL the parts catalogs don't break the serial number down to months, just to the year.
Old Jul 27, 2008 | 06:25 AM
banjopicker66's Avatar
banjopicker66
ND: The books I have show the month breakdowns for all years. Perhaps my books are different? They are the original ones from Ford.
Old Jul 27, 2008 | 06:36 AM
NumberDummy
In yours: General Information Section / Page 37.
In mine: General Information Section / Page 37 = Numerical Sequence of Assembly. The serial number broken down by years only.
The 1964/72 Ford Truck Parts Catalog I'm using, is the last printing: January 1975.
Ford dropped that month info because it really isn't necessary.
From the looks of things, your book is one of the earlier ones that has info from 1961 thru 1969.
Ford later put two books together: 1957/63 / 1964/72.
btw: Now if someone's into Astrology and they want to know their truck's sign... I could see them wanting that info!
Old Jul 27, 2008 | 08:27 AM
blloyd's Avatar
blloyd
Smile
I do not have a parts manual, so can someone tell me what month my
1962 was built at # 292496.
I could not quite make out the numbers on the photo from Banjopicker66 !
Old Jul 27, 2008 | 09:18 AM
NumberDummy
I do not have a parts manual, so can someone tell me what month my 1962 was built at # 292496.
.. May 1962 ..
Old Jul 27, 2008 | 10:06 AM
blloyd's Avatar
blloyd
Thanks ND, It's nice to have as much info as possible for historic and sentimental reasons !!
