No start on warm engine?
Old Aug 7, 2008 | 11:53 AM
  #31
MADVAN's Avatar
MADVAN
Originally Posted by Action4478
I thought about extending the wires to another sensor..It would work then ...
I have what you could call a HX mod hose with a ICP on the end of it.
The hose is long enough to reach the harness no matter where i tie
into the oil system. Works good for quick tests.
Bill
Old Aug 7, 2008 | 11:58 AM
  #32
tjbeggs's Avatar
tjbeggs
Bill
I was thinking about something likethat! that would be handy! I need to build one of those and get some JIC plugs for the hoses as well.
Old Aug 13, 2008 | 10:23 AM
  #33
CampSpringsJohn's Avatar
CampSpringsJohn
Any updates?
Old Aug 13, 2008 | 11:16 AM
  #34
kelro's Avatar
kelro
Yes, I do have an update. I pressurized each head with the grease gun filled with 15W40. One head would take several minutes to bleed down from 2500PSI. The other head could not be pumped above 1500 psi and would immediately bleed off. I have been gone but am back now and have the injector orings. I plan on doing all 4 while the valve cover is off although just one may be leaking. I think I got a bad set of orings as I redone the other side before.
When the other side was acting up the high pressure reservoir would always be low but it is staying up now. THat is what had be baffled about the whole deal.
Thanks for the help,
Kelly
Old Aug 13, 2008 | 02:32 PM
  #35
Action4478's Avatar
Action4478
Kelly
It may well stay up when the oil is cold...
Bobbys Big Red Rig
23
Sep 23, 2013 07:40 AM
countrycar
Nov 21, 2012 07:16 PM
caveman44
Apr 3, 2012 09:08 PM
John Henderson
Dec 29, 2005 09:57 AM
Bill_W
Nov 16, 2004 08:32 PM
