No start on warm engine?
Old Aug 7, 2008 | 08:11 AM
kelro's Avatar
kelro
Will the scan tool work or do I need to isolate the heads? The oil level in the high pressure reservoir is staying up once I reload it from pulling the IPR.
Thanks
Kelly
Old Aug 7, 2008 | 08:18 AM
Action4478's Avatar
Action4478
A scan tool will give you the overall picture ,, Isolating the heads will tell you which side of the motor to deal with
It could be a poppet issue also ,,,do the pressure test first.
Poppets can be verified with a feeler guage with the covers off ...
Info on that ...
The poppet valve is the one single area of a PSD injector that just flat out wears. It's similar to a valve in a cylinder head that beats itself into it's valveseat.
As the poppet valve opens and closes (with each injection), it meters the high pressure oil flow in/out of the inj.
With each opening and closing, the seat is being hammered by the valve...causing it (over millions of cycles) to seat lower and lower into the injector...until clearance under the armature is lost.
Once the armature bottoms out on the inj body, the valve cannot "reach" the seat to seal high pressure oil from leaking out of the injector.
The reason that the truck runs when cold, and dies (and won't restart until it has cooled significantly) is that cold oil is thick...and can bridge the gap created by a poor valve & seat seal.
once the oil is warm, it thins out, and can now leak around that valve creating a tremendous amount of "spillage" that the oil pump can not now keep up with...once the amount of the leak exceeds the capacity of the pump...pressure falls, and the injectors simply cannot fire without (approx) 450psi of high pressure oil...so the truck dies.
you can physically measure this yourself.
Pull both valvecovers, and start the truck...it won't be horribly messy, just a little oil splash around the valvetrain.
As the truck (oil) heats up and dies, have someone crank on the starter attempting to restart the truck.
You should be able to look at each injector, and find one that it puking oil out from around the (just above) the hold down clamp.
You may need to mop up any oil that settles down in the low spot of the head to help you see which injector is actually puking...
once you've isolated which inj(s) are puking, pull the solenoid (4 # torx 15 screws), remove the harness to that inj, remove the little aluminum spacer plate...
what you are now looking at is the armature plate...the little ~1"x1" square plate, with the goofy screw (poppet screw) going through it's center.
On a brand new injector, there should typically be .003"-.004" (three to four thousanths of an inch) gap under that armature (measured with a feeler gauge)...
My bet is that your injectors have enough poppet seat wear that they have less than .0015 (less than one and one half thou of an inch) gap...practically zero.
if you can't get a .0015" feeler under the armature plate, then that injector is a problem, and it is a good indication that the others within that set need some machining to bring them back into spec. so that they will operate correctly.
Old Aug 7, 2008 | 08:33 AM
kelro's Avatar
kelro
Thanks for the help. All of the injectors have only 400-500 miles on them. The only thing that could have hurt them is turning engine over before oil and fuel rails were completely refilled.
Does it matter what stroke the piston or injector is in when you check the clearance? What do you file down or will that be clear once I get that far?
Thanks
Kelly
Old Aug 7, 2008 | 08:40 AM
kelro's Avatar
kelro
I thought I had better clarify one more item. It will never die on me. as long as its running it will keep going. If I shut the engine off, it won't restart until it the engine gets cooled out a little. What is the pressure when running with pedal on the floor? Mine was running around 2600 the other day. I am thinking that if that is close to maximum pressure, then I can rule out my high pressure oil pump. This is a stock engine, no mods at all.
Old Aug 7, 2008 | 08:45 AM
Action4478's Avatar
Action4478
If the injectors are new I would expect the problem to be an O ring ...(or two)
Old Aug 7, 2008 | 08:51 AM
kelro's Avatar
kelro
THanks for all of your help. Cn I have bad injector orings with the high pressure reservoir staying up in oil all of the time?
Old Aug 7, 2008 | 09:52 AM
fishmanndotcom's Avatar
fishmanndotcom
Info on that ...
action... i tried to rep ya but i gotta spread it around! that is some great tech with numbers! awesome!
-cutts-
Old Aug 7, 2008 | 10:42 AM
Action4478's Avatar
Action4478
Yes...
When Uppers aren't real bad ,,I would guess there are different degrees of bad ...
Old Aug 7, 2008 | 10:54 AM
Action4478's Avatar
Action4478
-cutts-
Thanks for the compliment ,,but I saved it from Dave @ Swamps ....
Old Aug 7, 2008 | 10:55 AM
strokin'_tatsch's Avatar
strokin'_tatsch
Info on that ...
wow, that is one heck of a post... rep points sent!!!!!
i would check/replace all of your injector o-rings and isolate the heads as action said if all the injector o-rings check out.
Old Aug 7, 2008 | 10:57 AM
Action4478's Avatar
Action4478
Thanks
Kelly
After thinking about it ,,,You may be able to use the scanner too...
By blocking one head at a time ,,the scanner should be able to see a lack of ICP ,,may be worth a try....
Old Aug 7, 2008 | 11:00 AM
kelro's Avatar
kelro
You are talking about plugging off the high preesure hose that feeds one head or the other?
Thanks
Kelly
Old Aug 7, 2008 | 11:07 AM
  #28
Action4478's Avatar
Action4478
After thinking about some more (I hope I don't hurt myself)
It can only read ICP from one of the two heads ,,so it will only work on the left ....
Sorry ...Thinking in between coats of paint ...stupid job getting in the way ...
Old Aug 7, 2008 | 11:27 AM
  #29
MADVAN's Avatar
MADVAN
You can plug the feed to the pass side head and still read the ICP.
Bill
Old Aug 7, 2008 | 11:34 AM
  #30
Action4478's Avatar
Action4478
Bill
I thought about extending the wires to another sensor..It would work then ...
