Bucking while Engine Braking?
Old Jul 25, 2008 | 07:14 AM
Pele's Avatar
Pele
When I was taught to drive stick, I was taught to leave it in gear while slowing down. The engine compression would slow the vehicle and it would save wear on the brakes as well as prevent the brakes from overheating.
Given that my truck is pretty heavy, I like to keep brake temps low.
Fuel cut will also reduce or stop all together the feed to the injectors and this will reduce fuel consumption... An added bonus in todays high fuel prices.
So I do this, but it gets a bit uncomfortable in the F350 because when I let off the throttle, especially at high speeds and especially with heavy loads, the truck bucks like I'm pumping the throttle.
Why?
Is this normal on a diesel?
Old Jul 25, 2008 | 04:19 PM
1957F100's Avatar
1957F100
Umm my 1993 F250 doesnt do that, i almost always leave it in gear while slowing down. Ill pull it out of gear at the last second before i stop usually around 1000RPM.
It sounds like there might be a problem with your truck.
Old Aug 31, 2008 | 02:14 PM
a711112a's Avatar
a711112a
i get the same surging in my f350 zf5 any one why it does this
Old Aug 31, 2008 | 04:19 PM
fellro86's Avatar
fellro86
I had that on my 86, and after I unplugged the fast idle solenoid, it stopped, can't say if it is the direct relation, just my experience.
Old Aug 31, 2008 | 09:10 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Fuel system cleaner and lubrication should eliminate the problem.
Old Aug 31, 2008 | 09:35 PM
a711112a's Avatar
a711112a
thanks Dave... i will try it.. what do u suggest to use??
Old Aug 31, 2008 | 09:52 PM
Dave Sponaugle
I use Diesel Kleen in my fuel on a regular basis.
Keeps everythig clean and lubricated.
With a problem like yours, I would change the fuel filter, fill it with Diesel Kleen before you install it.
Then dump the rest in the tank.
When you start the engine it will run a bit funny for a minute or so, but the strong dose should start breaking up an crud.
You should be back to normal (no surging) before the tank is empty.
Old Aug 31, 2008 | 10:45 PM
ford390gashog's Avatar
ford390gashog
Some trucks do this. I have found that when the injector pump wears and the dynamic timing is off the pump starts to surge fuel to the injectors.
76f350spercamprspeal
General Automotive Discussion
22
Feb 2, 2013 11:54 AM
IDIDieselJohn
Nov 7, 2012 06:53 PM
paddler
Apr 6, 2009 03:04 PM
psu1xj
15
Oct 28, 2004 02:19 PM
