Electrical short
Old Apr 2, 2003 | 07:58 PM
Zccornett's Avatar
Zccornett
Electrical short
Could this be the same problem i am having with my '86 F-250?
Old Apr 2, 2003 | 09:05 PM
Howdy's Avatar
Howdy
Electrical short
Hi!
It could be. Guess you've got a short, too?
Always check the state of your battery, alternator, and connections before you assume it's a short. Explain a little about what's going on.
Old Apr 3, 2003 | 06:02 PM
Zccornett's Avatar
Zccornett
Electrical short
well the engine was rebuit less than 50000 miles ago. Truck sat for about 2-3 years. Once you get it started it run good, but the battery drains when it sits for a day or so. alternator has been checked and is in good condition. i need to go through and check the connections.
Old Apr 3, 2003 | 06:52 PM
Howdy's Avatar
Howdy
Electrical short
I would probably clean all the connections real well and then check the battery out. If the battery was sitting, hooked up in the truck for a few years, it could be bad.
thegreatgate
May 8, 2016 12:59 PM
VindexInjuriae
Aug 14, 2014 05:43 PM
Warren Hart
Modular V8 (4.6L, 5.4L)
Feb 7, 2014 01:52 PM
davyhyde
Apr 9, 2013 08:01 PM
camo. bronco
1978 - 1996 Big Bronco
May 31, 2003 09:43 PM
