1978 - 1996 Big Bronco
Electrical Short Draining Battery ?
Old May 28, 2003 | 05:43 PM
camo. bronco's Avatar
camo. bronco
Angry Electrical Short Draining Battery ?
I have an 84' bronco with a 351Windsor . Every time I leave the battery hooked up for a period of time it drains. Nothing is on that'd do it. I've replaced the alternator, regulator, starter, solenoid, and battery.
If anyone has any ideas on how to find the problem or what it might be please share.
Thanks.
Old May 28, 2003 | 06:39 PM
Mil1ion's Avatar
Mil1ion
Click the link !
How To Find An Electrical Short
Old May 29, 2003 | 08:00 AM
Seabisquit's Avatar
Seabisquit
If you have a after market stereo radio installed..check there first. Or, anything else you have added by direct wire to your fuse panel.
Wayne
Old May 29, 2003 | 03:49 PM
GeoTracker's Avatar
GeoTracker
One thing to check is the rear cargo light. The light will stay on with the ignition off. I left it on accidentally once and never noticed that it was on. 2 days later I had a dead battery.
Old May 31, 2003 | 04:25 PM
Big Red Bronco's Avatar
Big Red Bronco
Hi Camo, your problem can be easy or a real bear. Do you have a trailer electrical connector? IF so, make sure it is clean, dry, and not shorting out. I have a bad one one the Big Red Bronco, and it destroyed some of the wiring, including the fuel pump power lines. The connector shorted direct battery power and melted several wires together.
If you don't think you have the necessary tools and knowledge to find a short then consider an auto electric shop. They specialize in electrical problems.
The other side is: once the problem is found, can you fix it cheaper then the auto electric shop?
Bruce (Big Red Bronco)
Old May 31, 2003 | 09:43 PM
saanders's Avatar
saanders
The dome light has always been my nemisis. I seem to turn it on occasionally when I push in the **** to turn the headlights off. The rear cargo light and the stereo were both mentioned earlier. Later models have map lights that can be inadvertently left on. If you have something other than the lighter plugged into the cigarette lighter socket, check it. Make sure that the glove compartment light and the engine compartment light go out when they should.
GreenMtnMan
1983 - 2012 Ranger & B-Series
19
Apr 26, 2020 08:14 AM
Luke Guihan
May 9, 2016 01:10 PM
WilleyJoe.62
33
Jun 18, 2015 06:31 AM
littlewillie
2004 - 2008 F150
May 1, 2015 05:25 PM
fishthebay
Electrical Systems/Wiring
Oct 30, 2005 09:15 PM
