ignition timing
Old Nov 6, 2002 | 09:18 PM
chris112lee's Avatar
chris112lee
ignition timing
alright, I'm still 16 and fairly new with a vehicle. One thing I've never done is set the ignition timing. Unfortunately I was being dumb and messed with the distributor. Needless to say, I need to find how to at least get it running to the point I can take it to my buds shop. It's an f-150, 302 TFI ignition in a '91. Thanks guys.
Old Nov 6, 2002 | 09:26 PM
steve83's Avatar
steve83
ignition timing
If you pulled any plug wires, make sure they're routed properly FIRST.
Loosen the dist clamp bolt, turn the key on (RUN position), use one hand to short something metal from the BATTERY terminal of the starter relay (on the fender) to the small terminal at the top (R/LB wire I think) so the starter engages, and twist the dist slowly back & forth until the engine fires up. Set it so the engine idles as fast as possible temporarily, but get a timing light soon. The instructions are printed on your emissions sticker either on the core support (where the hood latch is), the air filter cover, or the hood.
Old Nov 6, 2002 | 09:36 PM
Mil1ion's Avatar
Mil1ion
ignition timing
So you're young and you want to learn do you?
Well, have a look at these sites and digest as much as you can.
By the time you're doe learning the info here.
You can time any engine.
http://www.fordmuscle.com/archives/2000/03/timing/index.shtml
http://tpub.com/basae/40.htm
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 7, 2002 | 08:56 PM
kevincook's Avatar
kevincook
ignition timing
1979 300i6
Apr 26, 2013 10:48 PM
BigVig
19
Jan 8, 2012 08:07 PM
Snotpunk
Jun 24, 2011 12:57 AM
RAGaz
Sep 20, 2010 09:40 PM
dcara
Electrical Systems/Wiring
Nov 11, 2007 10:45 PM
