reprogram keyless entry
Old Nov 7, 2002 | 12:29 PM
tomasc's Avatar
tomasc
Post reprogram keyless entry
Is it possiable to program keyless entry tofuction with motor running?
Old Nov 7, 2002 | 08:56 PM
kevincook's Avatar
kevincook
I am not sure if this will work or if it will cause you to many other concerns. You could try taking out the key in warning switch. It is easy to due on most vehicles if you want to try it. Take out the ignition lock cylinder and you slide off the switch. If you take care it will not brake and you can put it back on if things do not work out. Thats the only thing I can think of trying. Let me know if you do it and it works. KEVIN.
Old Nov 8, 2002 | 06:48 PM
redeye rye's Avatar
redeye rye
